Windows 7: dxdiag does not detect sound card/no audio input device installed
11 Oct 2015   #1
tomatopicker
Hello
Once, I could get sound on my computer, but now I cannot get sound to play on my computer.
Dxdiag does not detect a sound card.
I tried uninstalling and reinstalling the sound card drivers, but it doesn't work.
System restore isn't an option, since I've unknowingly turned it off for the past year.
Here is my SF Diagnostic files and the dxdiag file.
22 Oct 2015   #2
tomatopicker
Another thing is that when I plug my speakers in, there is a loud buzzing sound that doesn't happen if the speakers aren't connected to anything.
23 Oct 2015   #3
fireberd
What sound drivers did you install? You list NVIDIA HIgh Defintion Audio as your Sound Card in your system specs. That is NOT your sound card, that is audio for HDMI ONLY.
Go to HP and download the correct sound drivers as a start.
23 Oct 2015   #4
tomatopicker
Alright. Installing the right drivers at the HP website worked.
Thanks!
23 Oct 2015   #5
fireberd
Bingo! Good deal. Thanks for the feedback that it is working.
No Audio Output Device Installed/No sound card found
Hello all, I hope you could help me with my problem. Recently, I got problem with my PC, just all of a sudden, it stopped booting and later on the HDD got wiped and I have no saved data. So I reinstalled using USB, before I was running Windows XP, but I prefer to install Windows 7. The thing...
Installed Windows 7, No Audio Device, Sound Problems
Hi Everyone, I have recently changed my OS to Windows 7 and have sound problems saying No Audio Device. When I used windows update, it installed VIA AC'97 Enhanced Audio Controller successfully, but that only works occasionally. The sound goes blank all of a sudden. I have tried other audio...
Drivers
Problem with sound device with audio input.
I got a problem with my audio system. I have got two sound devices for my PC and one of them is not working. I have got one Philips Subwoofer which works fine, it has got a audio input. Also I have got a Philips Tv-flatscreen used as main monitor which is connected with a HDMI-cable. Ever since...
Device manager does not detect sound card. Experienced builder stumped
I recently reformatted my system, and ever since my computer refuses to recognize my sound card as installed. You can see my system specs in my profile, but it is a Soundblaster Xtreme-Music card. I've updated and double checked all of my mobo drivers and I still cannot for the life of me get this...
Hardware & Devices
'no output audio device is installed' but sound plays
As above. It says this in the icon in the tray, yet i can play songs fine. The only thing is, it also has my speakers to record, and i can't change it to front mic. any ideas? it was working perfectly fine yesterday... sound is onboard and uses Via hd audiodeck. thanks
No Audio Output device is installed! no sound! :(
Hello everyone, i have seen this posted before but my problem is a little different. I can not even find what my sound card is or where it is. I have looked and looked and there is nothing on my computer to show it has a sound card. It did indeed work before i upgraded to 7 so it has to be there....
