Windows 7: How do I fix having no sound in my browsers?
04 Nov 2015   #1
BasedDoge
windows 7
I tried everything i could find on google and reddit and nothing worked. checked the sound bar, reinstalled flash, system restored, restarted my browser, refreshed the page, disabled and enabled the flash plug-in and nothing fixed it. Actually, when I messed with the flash plug-in SOME youtube videos worked but others didn't. I messed with it again Now none work, was enabling and disabling it, I think it worked for some videos only when disabled. Do some youtube videos work differently? When searching on Google I also found something about changing my realtek settings from 7.1 to stereo or something, how do I do that (if that would fix it)?
P.S. I have firefox and chrome (I mostly use Chrome) and sound works on my PC, just doesn't work in my browsers.
04 Nov 2015   #2
fireberd
With regular PC sound working, it says the PC sound is not the problem. The problem is application software or browsers.
Try using Internet Explorer and see if it works there. Reposting in browser section of the forum may be more applicable.
04 Nov 2015   #3
AddRAM
Windows 7 Pro x64 Windows 10 Pro x64
You change it by going here, right click on the sound icon in the taskbar.
Eliminate all Browsers that are 'default browsers'
I do not like having any browser as my default browser. I use Firefox, Opera, and Chrome and sometimes have 2 browsers loaded concomitantly. I mistakenly made Chrome my default browser, how do I reverse this process. I removed Chrome via the control panel but when I reinstalled it it was still set...
Browsers & Mail
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Sound works on certain videos, but not others (Across all browsers)
(I'm sorry if this has been answered before, but I couldn't think of a way to search for it) When viewing videos on any of my browsers (Firefox, Chrome, and Internet Explorer) for some reason there is no sound for some sites like Youtube or ESPN. But if I go to msn.ca (I only found this...
No Sound and flash plays jerk-ish in all browsers.
After trying out Chrome OS in VirtualBox, well, i didn't managed to try it at all, VirtualBox hanged and i did a force shutdown. As a result, i've seemed to have lost the ability to play any sound from anywhere and flash videos played horribly jerky. Before:Here GGT8ZCTBoBA After(first...
Browsers & Mail
browsers bog down
Every so often, particularly after changing sites, the browser (happens both with IE and firefox) does not connect, waits and waits until the message comes that this site can not be connected. The internet is connected as seen in the taskbar and switching users readily connects with the desired...
Browsers & Mail
