Windows 7: Rear audio output doesn't work
17 Nov 2015   #1
Newmaven
win7 Pro x64
I have speakers plugged into the rear audio jack of my PC and (usually) a headset plugged into the front mic and earphone jacks. When I unplug the headset, I get no sound from the speakers. I've verified that the speakers work fine from other sources, and the headset gets no sound when plugged into the rear output jack.
How do I diagnose and fix this?
18 Nov 2015   #2
fireberd
More system info is needed.
One possible problem is a front panel jack problem that the PC thinks a headset is still plugged in after its removed. To check that the front panel is not causing the problem, disconnect the front panel audio connection from the motherboard and see if that fixes it.
Keyboard for some reason doesn't work in rear ports.
My microsoft 600 usb mouse and keyboard suddenly do not work properly anymore. Whenever I plug them into the rear ports they disconnect and freeze(computer remains running). It sometimes requires a reboot for it to work again. This is really weird and frustrating as I can run my other devices out...
Hardware & Devices
Realtek ALC889 audio, audio fine on S/PDIF, nothing from rear output
I'm having a strange problem in my HTPC. Audio is coming perfectly fine out from the S/PDIF coaxial output, and it's normally connected only that way to the receiver, but now for other reasons I also need to connect it using a 3.5 mm to a small mixer. So in the sound manager I changed the output to...
HDMI Audio output - how to get it to work???
I only have this problem with 7, so I know it is not a hardware related issue. I simply can not get any sound out of my graphics card (seemingly) through HDMI. I have my bios setup to play audio from it. I've followed what everyone else has done when using the search, I have zero success. ...
Can't get Rear Audio jacks to work While cable connected to front jack
I am fairly new with W7 so please excuse my inexperience with this. I have headphones connected to front headphone jack (Dell Inspiron 560 W7 Home 64). I want to have cable connected to rear jack (for speakers in other room). I can't get audio from the rear if anything is connected to the front...
No Audio Output via Front and Rear Jacks
Hey guys, I installed the Hyper 212+ this weekend, but after installation, the audio stopped working. Thinking that this was a hardware issue, I went back and replugged some of the cables back into the mobo to make sure they were securely in there. No luck. My setup (other specs in profile):...
Radeon 5770 HDMI output doesn't work
My machine is fitted with a Radeon 5770 video card. I normally connect to my monitor via the dvi output with no problems. However when I noticed that both the monitor and the video card have HDMI ports I tried connecting with a HDMI cable. The result was a "No Signal" error on the monitor and no...
Graphic Cards
