Windows 7: Playing sound will just suddenly go silent unless I press volume/mute
21 Nov 2015   #1
mbratch
Windows 7 Pro 64-bit
This is problem that just one day came into being on my laptop running Windows 7. I can't associate it with any particular update since I don't play videos or sound files frequently.
Here's what happens. Let's say I got to YouTube and play a video. The sound will work for about 30 seconds to a minute. Then it will suddenly stop. The video still plays. If I toggle mute (press it twice) or press the volume up or down, the sound comes back but it doesn't last as long. To listen to something, I have to stand ready at the volume (one click up or down) or mute (two clicks) button to press it any time the sound goes away. The same thing happens if I play an mp3 on the music player. So it's not browser plugin related. It seems either sound driver related, or even a HW issue perhaps.
I just upgraded to Windows 10, using a completely different browser and the problem is still there.
Does anyone have any idea what might be causing this?
22 Nov 2015   #2
fireberd
What do you have listed for the sound? The actual hardware sound driver or the generic Windows installed High Definition Audio Driver? If you don't have the actual hardware sound driver, that is the first step.
22 Nov 2015   #3
mbratch
There are two things listed under Sound in the device manager:
Conexant 20585 SmartAudio HD
Intel(R) Display Audio
22 Nov 2015   #4
fireberd
That's the correct sound driver.
If you just upgraded to 10 and still doing it, could be hardware, sound driver (the Win 7 driver may not be Win 10 compatible or at least not 100% compatible). Check Lenovo and see if there is a later driver, at least a Win 8.1 driver.
Mute Sound Icon Box suddenly flashing on desktop - can't turn off!
All, Can someone please help me figure out how to turn off the icon that suddenly started flashing randomly on the left side of my desktop? It is a box with a speaker with an "X" through it. It flashes vertically up and down the left side of my monitor. My OS is: Windows 7 Home Premium...
Sound stops playing after changing volume
Hi everyone, I have a rather odd problem... My sounds works fine, then as soon as I change the volume (either through the icon in my taskbar, through the volume control on a youtube video, or by the volume wheel on my headset), my sound crashes. It always makes my youtube vids throw an error and...
Volume control set to mute on startup
I am curious as to why the volume control is muted on boot. The system sound is set to "No sound". The tech info about my desktop is in my signature.
How do I make my volume mute when my headphones come out?
Hey so I have (what I think) is a basic question. I listen to the radio on my work computer. What I am trying to do is have it so the volume is on mute all the time, but when I plug in my headphones it un-mutes. Then if the cord comes out by accident it goes to mute without playing any sound....
How to keep System Sounds at 0 volume or mute?
I find System Sounds does not stay at 0 volume or muted, with one exception: when volume mixer is open. When I close the volume mixer and open a program that requires UAC, the chime is at "full" volume of selected device's volume setting. As examples, Piriform's CCleaner and Revo's...
Volume mixer: way to create a shortcut to mute an app?
Hey there. I was wondering if there is a way to create a shortcut to mute/unmute (or 2 shortcuts: one for each function) an specific application. For example, I am constantly muting/unmuting Firefox because I am listening to music most of the time, but when I need to listen to something I gotta...
