Windows 7: System Sound Issue
04 Dec 2015   #1
zamag
Windows 7 Ultimate 32bit
System Sound Issue
Hey Guys
Just wanted to thank you for my 'System sound' fix I found on this forum.
I was battling with this problem for some time now.
04 Dec 2015   #2
oscer1
win 7 64 bit
hi glad the forum could help you.
04 Dec 2015   #3
thelma
windows 7 professional 64 bit
Can you tell me what you found, might help me .....
Thanks a lot
07 Dec 2015   #4
zamag
I found everything that was suggested to be in order in my computer.
The last thing I tried was to delete the the drivers under the Device Manager-Sound,video and game controllers.
After restarting the computer then the sound came back.
07 Dec 2015   #5
thelma
Thanks Zamag , I will try that now, I am at the end of all possibilities, let you know if it works.
Did n't work, for the 200 time it reinstalled my old drivers from 2009, mind blowing, got the newest Realteck installed in programs and features. Does not want to know.
07 Dec 2015   #6
oscer1
win 7 64 bit
Do headphones or external speakers work
07 Dec 2015   #7
thelma
Yes Oscer , see my massive "Monologue" in sound and audio dd only Yesterday, there is the story ( as far as I can understand it ??? )
 System Sound Issue
Reoccurring low sound issue affecting two sound cards
I had this issue before, all of a sudden the sound coming from my computer gets really quiet even though everything is maxed out. Before, it seemed to have been triggered when I moved my computer from one room to another. I wasn't able to move it back right away but when I did it was still...
RealTek OnBoard Sound Issue - No Sound
Hello everyone, My audio has seem to quit on me. I updated to the newest drivers for my mobo (biostar A870U3) from their download page and now I get no sound whatsoever from my speakers. I have tried uninstalling all of the sound devices from the device manager and letting windows reinstall...
Sound Blaster X-Fi Titanium Sound card issue
I have put the sound card into my computer and made sure that I've hooked up everything correctly, but I have ran into a problem with it. When I ran the download "Product Identification Module Update" from the Creative website, it's telling me that I don't have the right OS, and tells me to update...
Soundcard (possible) related issue, sound loss/ system slowdown.
My system has recently developed an annoying problem which is causing me some concern as it could indicate something serious. Quite often when it boots up, there is instead of the properly functioning sound, a continuous high pitched whine. This goes away when I reboot. Sometimes though, this...
Sound issue (Conexant sound driver)
Ok, first of all, i'm not sure how to properly explain this, because it's confusing, but i'll try my best and if any more information is needed please let me know! So, I bought this packard bell laptop preinstalled with windows 7 from pc world in September. And for as long as I can remember,...
System Event - Changing sound makes a sound, how to mute it?
Did my searching and couldn't find this one... When I modify the speaker volume using the "Volume Mixer" icon, it generates a sound. When I adjust using the "Speakers/Headphones" icon, it does not make a sound. I would like to mute the Windows 7 sound that happens when I adjust the sound,...
