Windows 7: Headset volume low with optical compared to USB
16 Dec 2015   #1
Dranem
Hello,
I recently got a Steelserie H Wireless, and I plugged the transmitter to my PC using optical for output and USB for input (which can also be used for output). I have a Realtek HD audio card, onboard with the motherboard.
When in windows audio settings I select USB output in the playback devices, the sound has a good volume range (up to "painful for the ears") but it feels close to the ears, rather flat, whereas when I select optical output, the sound gets really volumetric (like it's filling the whole room), so great quality, but the maximum volume is barely good enough, really low (and both PC volume and transmitter volume are at max). Is that normal ? And is there something to do to improve the volume level with optical ?
Thank you
05 Jan 2016   #2
Dranem
Well just a follow-up if someone is interested : I didn't solve my problem. I wrote to Steelserie and after asking me to do a few basic manipulations, they asked me to fill a warranty return request, which I did. They then accepted it, only to recant it 7 days later with no explanations. Luckily I hadn't sent back my headset yeta at that time. So I guess I just wanted to say somewhere that Steelserie has shitty support...
Else if someone has an idea I'm all ears.
My headset has low volume when plugged in speakers
Hi, I bought a new headset today, identical to that of my sister, which is very loud ( in a good way). So, when I plugged the set to my speakers I was disappointed because it was lower than that of my sister's. But then I thought to plug it to front green panel of the unit and boom!!! the sound was...
Will a Headset microphone still work if I cut it off the Headset?
I have a almost broken headset, but the microphone still works fine, The microphone is connected on the wire right before the headset, Its not actually touching the headset itself. Would this microphone still work if the headset was cut off? Sorry but I can't manage to take a photo but
Hardware & Devices
Encrypted Volume Check: Volume Info on \\?\Volume{X}Can't read
Encrypted Volume Check: Volume Info on \\?\Volume{X}Can Not Read Found this in my Event Viewer on each start/restart. I don't have any Volumes that I have encrypted. Is this malware? I've run everything prior to noticing including Windows Offline Defender. Not sure if this is even the...
General Discussion
Headset and volume controll
Hello everyone! I've bought a plantronics gamecom 780 headset. It came with a cd software. The thing is that the headset has a volume controll on the headset. The headset is usb not 3.5mm jacks. I've installed the software and everything works great but the volume controll doesnt do anything it...
Volume problems with Microsoft Headset.
Hello, i have a Microsoft LX-3000 Headset, sound and the mic are ok, but the volume buttons aren't working on 7 (ok on XP), and when I need to adjust the volume I need to set it on the control panel :shock: Someone with the same issue?
Low volume on headset
My volume on my Steelseries 5H v2 is pretty low and im pretty sure it started after i got win 7 64bit. My volume should play twice as loud as it does right now, it also makes a little constant noise when no sound is played witch is annoying. I tryed checking everything in the sound options and...
