Windows 7: Sound issue
09 Jan 2016   #1
Laith
Windows 10 Professional x64
Sound issue
So i bought a custom built PC and when i try to plug in my headphones into the headphone jack it doesn't work, any help?
09 Jan 2016   #2
z3r010
Is the jack on the front of the case? I know I had a real bad habit when making custom PC's of forgetting to hook them up
09 Jan 2016   #3
Laith
No it isn't. It's on the back, the front ones aren't connected to the motherboard.
09 Jan 2016   #4
Laith
Uh oh, seems like i can't plug in my mic aswell
It works, sound doesn't.
09 Jan 2016   #5
fireberd
The "headphone jack" on the rear is actually the GREEN speaker jack. Is this the one you are trying to use?
Is the "Speaker" (PC Sound card) set as the default audio playback device? or are you using HDMI, which in that case the HDMI is set as the default audio playback device and there will be NO audio at the PC's speaker out. However, with HDMI set as default, the front panel headphone is usually still available. If this is the case, hook up the front panel headset/mic jack. The cable from the front panel can be labeled HD Audio or AC97. Either can be used but the HD Audio is preferred as it has jack sensing that the older AC97 does not have.
09 Jan 2016   #6
Laith
Thanks so much fireberd. The problem was that HDMI audio was the default output. Thanks once again!
09 Jan 2016   #7
fireberd
Cool. Glad I helped and thanks for the rep.
Jack
09 Jan 2016   #8
Laith
No problem!
 Sound issue
Reoccurring low sound issue affecting two sound cards
I had this issue before, all of a sudden the sound coming from my computer gets really quiet even though everything is maxed out. Before, it seemed to have been triggered when I moved my computer from one room to another. I wasn't able to move it back right away but when I did it was still...
RealTek OnBoard Sound Issue - No Sound
Hello everyone, My audio has seem to quit on me. I updated to the newest drivers for my mobo (biostar A870U3) from their download page and now I get no sound whatsoever from my speakers. I have tried uninstalling all of the sound devices from the device manager and letting windows reinstall...
Sound issue
http://www.facebook.com/photo.php?fbid=10151290051553689&set=a.150914573688.136450.672368688&type=1&theaterHello, Everything worked fine yesterday no programs or changes to pc. This morning no sound. Under control panel individual device has fluctuating sound indicator. Under volume mixer...
Sound Blaster X-Fi Titanium Sound card issue
I have put the sound card into my computer and made sure that I've hooked up everything correctly, but I have ran into a problem with it. When I ran the download "Product Identification Module Update" from the Creative website, it's telling me that I don't have the right OS, and tells me to update...
Sound issue (Conexant sound driver)
Ok, first of all, i'm not sure how to properly explain this, because it's confusing, but i'll try my best and if any more information is needed please let me know! So, I bought this packard bell laptop preinstalled with windows 7 from pc world in September. And for as long as I can remember,...
Big sound issue!
Hi every1 on 7 forum! I'm new here and my English is not so good so please don't get angry by it. I'm a hugh fan of my 7 OS and I wouldn't change it for anything (first thing to know). On my job I work on CentOS remote server with no GUI and it is hard to learn it so I decided to shrink my C...
