Windows 7: Switching between onboard sound and external sound card
13 Jan 2016   #1
perkinw
First, let me say that I am a sound novice! I recently started a vinyl ripping project. My onboard sound does not support 24 bit depth recording at 96 kHz sampling rate, so I purchased an external USB card with phono preamp. It works just fine for my project. But as long as external sound card is plugged into a USB port, it takes control of all sound. I'd like to be able to toggle back to my onboard audio when I'm not ripping vinyl so I can listen through my system speakers. I have experimented with Windows audio controls, but have not found a way to do this. Is it possible?
13 Jan 2016   #2
whs
Microsoft MVP
Did you check whether there was a switching option in the BIOS
13 Jan 2016   #3
perkinw
Quote   Quote: Originally Posted by whs View Post
No, I have never examined my BIOS settings.
13 Jan 2016   #4
AddRAM
Windows 7 Pro x64 Windows 10 Pro x64
Why isn`t this working ???
13 Jan 2016   #5
perkinw
Thank you! That solved the problem.
It takes about 60 seconds for the Sound dialog to appear after right clicking on the loudspeaker in the system tray and selecting "Playback devices." But then if I change the default playback device to "Speakers/Headphones RealTek" the sound plays through my speakers.
S/PDIF Optical out - No sound from receiver (onboard and sound card)
I've got an Asus Crosshair V Formula motherboard that I couldn't get any sound on my Onkyo HT-R550 receiver via the onboard optical output (Win 7 Ultimate 64 bit OS) I was planning on getting a nicer sound card anyway, so I bought the Asus Xonar Essence ST. Installed that sound card but alas, I...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
onboard sound vs. Addon sound card
What would be the advantages/disadvantages of onboard sound vs a sound card? With a sound add on card are there headers for front panels connections.? Would I see/hear a big difference in the sound?
onboard sound card question
sup fellas, have a stupid question for you... Just switched my desktop to windows 7 from xp pro and have a weird latency with my audio. This latency did not exist on XP, but with 7 it is there. I have been using just my motherboard soundcard (desktop for recording) with the 6 1/8" inputs ......
Enabling onboard sound with a sound card
Hi, I fly MS FSX and I want to be able to chat to ATC with my headphones and then hear the engine noises coming out of my speakers and sub-woofer. I have a soundcard and my motherboard has onboard sound. I can't find the bios setting to turn it on and I can't see any hint of it anywhere on the...
Figuring out onboard sound card
my friends computer has an on board audio sound card that we dont know the name too and the computer was reformatted. Tryin to look up model but not luck, it was built by hand. Any way we could figure this out now? or is it a bit too late. If its late, we could always just buy a sound card, but...
Drivers
