realtek audio pop when audio plays, subwoofer thump
https://rog.asus.com/forum/showthrea...or-audio-files
The issue:
With realtek drivers from either realtek OR the Asus site, I get audio pops/thumps anytime audio is played from idle. Windows navigation's "click" noise turns into a super short "tick" After 10 seconds idle, it's a louder "tick", and when an audio channel is kept open, stuff sounds normal. Even opening a webpage that opens an audio channel makes a nasty crunch sound.
I am on the new ROG Asus Hero Alpha with a 6700k, stock settings in BIOS.
5.1 speakers I am using:
Amazon.com: Logitech Surround Sound Speakers Z506: Electronics....
Also used my previous builds speakers that never had any issues (good ol' dell):
http://stuartconnections.com/products/Computers/Periphe...
*Windows default audio drivers work 100% normal*
This forum also describes my issue:
http://forums.whirlpool.net.au/archive/2317852
I have done the following:
Stock BIOS
Updated BIOS
Don't even have my GPU in yet, but that works fine and doesn't change anything
Tried multiple drivers, each time clean uninstall/install
Reformatted countless times
Removed all interference/wireless stuff
Used previous builds PSU and 2 new ones
Swapped all components muliple times
Used different outlets/plugged all into same surge protector strip / tried different surge protector strips
Tried many different drivers/MEI code updates from intel from their own site
Playing with all audio settings / volume levels
Disabled any audio settings not being used, no micophone
Ran PC at performance, turned minimum cpu usage to 100%, disabled C states, speedstep, or any power saving features, EIST disabled.
I have not installed AI suite, I am literally running the bare minimum
Tried different sets of speakers, all speakers work everywhere else normal anyway (speakers confirmed working)
I have the hyper evo heatsink and put it on lightly so it's not pressing hard down on the CPU just to eliminate that being an issue
I have removed USB's, ethernet cable
Used different cables, checked all cables, used the minimal cables/hardware (no extra HD's or fans)
Tested PSU with PSU tester AND Multimeter, as well as the outlets
I've done basically everything you can find on the internet about this issue, I may have not listed all here.
I know my DPC latency was low, there weren't any crazy abnormal spikes
Literally, this only happens with the realtek/Asus drivers, so hardware should be fine, especially since I went through replacements.
I'm running G.Skill RAM that others in another thread are using without any audio issues. RAM has been stress tested, and is running at stock. They are in the correct, suggested slots. I am running the 6700k at STOCK. All stock BIOS 1402. BIOS updated without an issue. Windows 7 64x pro is installed correctly on my SSD. Only the SSD is plugged in and the M8HA is installed on a bench. I have a 850w corsair PSU.
I have swapped through 3 CPU's, 5 mobo's, 2 PSU's, as well as trying my previous builds one, 2 sets of ram, and an extra replacement on the M8HA. I get the same issue each time. I have used the hardware on a Gigabyte, and an MSI, both which did not have this audio "tick" sound. They did have a sizzle sound anytime an audio channel opened though. This has been going on for months. The gigabyte had that constant hissing sound through headphones when the CPU was doing calculations, so basically all the time. Moving the mouse across the screen made it hiss louder. MSI and Asus don't do that hissing. Could this all lead to a ground issue? My outlets seem fine and the grounding is working, plus no other devices have issues.
Asus admitted to this problem to me over the phone multiple times, as well as looking online at it to further investigate. Technical support suggested me after a week, to make sure the correct colored cables are plugged into the correct colored ports on the motherboard...
What could possible be causing this? I have read a lot on power management relating to it. I ask people if they're on stock or OCing, because if you OC you may be keeping the power higher, so on idle it doesn't power down much. I see a lot too on people having laptops with this issue and they can disable power management on their realtek settings. Desktops don't have this. I tried doing it through registry but those registry files didn't exist for power management.
Here are links to the audio files. Quality isn't the best but listen closely between the "ticks" and regular full window "clicks" I also mimicked the "thump" that plays I think through the bass, because my phone wouldn't pick it up, I mimicked it in a separate file because this "thump" plays right before the audio channel opens.
Tick1:https://clyp.it/5evymx2y
Tick2 (good clear ticks):https://clyp.it/q1aura1a
Thump noise (it's a settle "thump" so bear with me):https://clyp.it/2fkyj3ad
Regular windows click noise with windows default/audio channel open (full long regular click we all know navigating through folders):https://clyp.it/cctps45v
Please bear with the quality, it sounds so much worse in person for what I am talking of, but just this is to understand it further.
Please someone help me with this. I've been through so many replacements just to eliminate hardware, and now it's literally down to the drivers, unless some hardware is really bad and hiding good. All points to the drivers, and specifically realtek (all other drivers work with windows default audio driver)
I really hope enough people can help troubleshoot this. I just don't get how some are running a similar set up and have no audio issues.
