Windows 7: Nidda Help on creative sound blaster live 5.1 SB 0220
09 Dec 2009   #11
Quote   Quote: Originally Posted by stormy13 View Post
Your 2ZS may be EOL, but at least it is still receiving updates (albeit slowly) for 7 and Vista.
Regarding the more than 2GB of ram issue, it is a straight up driver limitation and enver get fixed unless someone wants to try and reverse engineer the drivers and add the support.. You have to consider how old that card is and when the drivers where written, 2GB was considered a massive amount of ram (not too mention how much it cost back then).
Actually the updated drivers from Creative simply do not work, per usual with Creative support. I consider non functioning drivers the same thing as having zero support.
In fact the only ones that work and have creative support are the ones made by Daniel K, but creative forced him to take out all the sound adjusting functions making them nearly worthless in my opinion. Once again, zero support.
I've been doing this a long time, been there done that, years ago in fact, back when Vista first came out and as per usual once again had zero support for my Audigy 2ZS. If not for Daniel K. we would all still be in that boat, I remember the entire blow out at the creative forums and witnessed it all live. So you can probably spare on the history about these drivers. I know all about it.
In the mean time I'am using the torrent I found hosted by Daniel K. These drivers work perfectly and also have full function on all sound adjustments, EQ everything working flawlessly. Perhaps you weren't aware of this fact?
Most of his drivers can be found in the non stripped down versions by looking for the torrent. The ones you posted are some BS generic stripped down Daniel K drivers which are the only ones that Creative would let him post on their site.
25 Dec 2009   #12
windows 7
it still not working just old drivers are workng and front speakers giveing sound but mic is working its ok wtih kx drivers mic not working and just center speaker giveing sound what a ashame need to be a good company creative but look cant write easy driver for it
i have SB0220 and i sent email to creative and they wrote me use older version of ur operation system .They try to say creative company cant write a new drivers for windows 7 our old products are not supporting windows 7 im asking this question is it a new game ? new sound technologys for one operation system ok if it will be at windows vista i can accept vista problems but windows 7 ??? i dont think its a problem for it how it can be my audio card is not supporting windows 7 profeesssioan sound effects what a stupid idea... and still not any driver is working good for windows 7
İ think creative trying to say we are so bad company and cant support one our product just we need to write on new driver but we are so lazy we like to earn money but we dont like to support...
21 Jul 2012   #13
Ahsan Mansoor
windows 7 32 bit
i need windows 7 driver for creative sb0220 & i can not find it any where,,and windows 7 does not detect my sound card as well ,,can some 1 please help me.....
21 Jul 2012   #14
Windows 8.1 Pro x64
Quote   Quote: Originally Posted by Ahsan Mansoor View Post
We seen your thread, please do not spam the forum. we will help you when we can figure out the problem.
31 Oct 2012   #15
Windows XP Pro 64
i have got the same sound Card a creative sound blaster 5.1 works brilliantly with XP & have hap it for many years, as soon as I tried SB Live! series Support Pack 1.5 (08/09/2009) with windows 7 Home premium It CRASHED big time so to all you poor souls with creative sound blaster 5.1 cards we are doomed to either throw them out & to buy New all because the sound card is OLD in this day & age that is tragic. A great working bit of kit is now defunked im off to buy a usb devicecry:
Search this Thread:
Advanced Search
Creative Sound Blaster 5.1 live
Hi hope someone can help i am very new to this forum, at this moment i running XP Pro I want going to upgrade To Win 7 but it not recognise my Creative Soundblaster 5.1 sound card which is working fine under XP with all that i use i have been on web site to try & find driver for it. someone posted...
Creative Sound Blaster Audigy 24bit Sound Card
I installed windows 7 a little while ago but i cant seem to get a driver that will recognize my sound card. the computer doesnt think its installed correctly but when i was using Xp it was just fine. ive tried another PCI slot but no such luck. all of the drivers i have tried tell me that they dont...
Creative Sound Blaster 5.1 SB 0220 WIN7 32 BIT DRIVER ?
hi I need Creative Sound Blaster 5.1 SB 0220 WIN 7 32 BIT DRIVER ... which support pack ? thanks ...
Creative Sound Blaster Live 5.1 - Bass, Treble Balance
Hello, I have Creative Sound Blaster Live 5.1 running with EMU10K1 driver on Windows 7 7260 x86 build. Sound is OK, but there is a problem with Bass and Trebele Control - this control is freeze on minimum and doesn't work. Please, anybody have idea? Thank you very much. ...
Creative Sound Blaster Live 24 Bit - No Subwoofer
Hi Guys! I hope I'll get an useful answer here! My problem is that i don't get any bass out of my subwoofer, my system (as i configurate) recognizes my subwoofer, but as soon as i listen to music there's no sound coming out of it! My other speakers work, but only the bass is missing! I...
Creative Sound Blaster 5.1 Live!
Hello all. After 2 weeks of trying to get driver for my SB 5.1 live! sound card,i did nothing then tapping in place... Ive tryed everything ive remembered to but i still cant find any solution. I know its an old sound card,but drivers must be here somewhere... Im using Win7 v.7600 RTM 64-Bit...
