Nidda Help on creative sound blaster live 5.1 SB 0220
  1. Posts : 3
    what is OS??
    And anyone giv me the driver for this soundcard please.....i nidda this driver i got find the forums but i dont really understand what they saying....
    My RAM : 3GB
    SoundCard : Creative Sound Blaster Live! 5.1 SB0220
    Motherboard : i dont really know my motherboard because it have changed by the tecnicalman
    Processor : 2.8GHZ
    Windows : WINDOWS 7 ULTIMATE x32Bit
    Can anyone give the driver which can work properly properly!!! please please please
  2. Posts : 8,870
    I think you need to use the Creative software auto update near the bottom of this page.
    http://support.creative.com/Download..._1_01_0097.exe
  3. Posts : 6,879
    Win 7 Ultimate x64
    chev65 that won't do him any good as Creative declared that card EOL a couple of years ago, and there are not and will not ever be Windows 7 drivers for it. The only chance he has for drivers for it is this,
    SB Live! series Support Pack 1.5 (08/09/2009) - Creative Labs
  4. Posts : 8,870
    Those are the Daniel K drivers for audigy live. I'm using his drivers also for both of my EOL Audigy 2zs's.
    The problem with those is that they don't work consistantly with more than 2GB memory and the Op is using 3GB. You can read the responces there on the page and they don't look too good.
    I had to use the Daniel K drivers on my old outdated SB audigy 2zs which was also declared EOL long ago. They work much better than the Win 7 Creative ones which had that terrible static sound.
    Typical Creative non existent support.
  5. Posts : 6,879
    Win 7 Ultimate x64
    Your 2ZS may be EOL, but at least it is still receiving updates (albeit slowly) for 7 and Vista.
    Regarding the more than 2GB of ram issue, it is a straight up driver limitation and enver get fixed unless someone wants to try and reverse engineer the drivers and add the support.. You have to consider how old that card is and when the drivers where written, 2GB was considered a massive amount of ram (not too mention how much it cost back then).
  6. Posts : 20
    Windows 7 build 7600
    I acctually tried out this card really well.
    I tried ALL drivers for it on Windows 7 RTM Ultimate. Only driver that worked was kXproject one. It had all speakers and worked nice.
    Tho kXproject drivers that you can use on Windows 7 are BETA atm you can use them no problem.
  7. Posts : 344
    Windows 7, Linux
    Yup, and they even have 64bit and 32bit as of late. Very good sound, it's what I use and I've never been happier.
  8. Posts : 3
    what is OS??
    so...i wanna remove 1gb of RAM right????
    so that i can use it properly without crashing??
  9. Posts : 344
    Windows 7, Linux
    kX Project: Knowledgebase: kX Soundblaster Compatibility List
    Partially Supported
       Card name:
    Soundblaster Live! 5.1             SB022x
    Google KX Drivers, they are a godsend for certain creative cards. Yours is partially supported, but I'm guessing stereo should work crystal clear. I don't know if you are wanting 5.1, but it might be working just see what happens.
  10. Posts : 3
    what is OS??
    er.... sorry can give the download link???
