Nidda Help on creative sound blaster live 5.1 SB 0220
tommy0611
11:58 PM
And anyone giv me the driver for this soundcard please.....i nidda this driver i got find the forums but i dont really understand what they saying....
My RAM : 3GB
SoundCard : Creative Sound Blaster Live! 5.1 SB0220
Motherboard : i dont really know my motherboard because it have changed by the tecnicalman
Processor : 2.8GHZ
Windows : WINDOWS 7 ULTIMATE x32Bit
Can anyone give the driver which can work properly properly!!! please please please :cry::cry::cry::cry::cry::cry::cry::cry:
what is OS??
what is OS??
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
GSkill Phoenix Pro 120GB SSD
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
Those are the Daniel K drivers for audigy live. I'm using his drivers also for both of my EOL Audigy 2zs's.
The problem with those is that they don't work consistantly with more than 2GB memory and the Op is using 3GB. You can read the responces there on the page and they don't look too good.
I had to use the Daniel K drivers on my old outdated SB audigy 2zs which was also declared EOL long ago. They work much better than the Win 7 Creative ones which had that terrible static sound.
Typical Creative non existent support. :sarc:
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
Your 2ZS may be EOL, but at least it is still receiving updates (albeit slowly) for 7 and Vista.
Regarding the more than 2GB of ram issue, it is a straight up driver limitation and enver get fixed unless someone wants to try and reverse engineer the drivers and add the support.. You have to consider how old that card is and when the drivers where written, 2GB was considered a massive amount of ram (not too mention how much it cost back then).
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
I acctually tried out this card really well.
I tried ALL drivers for it on Windows 7 RTM Ultimate. Only driver that worked was kXproject one. It had all speakers and worked nice.
Tho kXproject drivers that you can use on Windows 7 are BETA atm you can use them no problem.
Windows 7 build 7600AMD Athlon 5200+OCZ 2x 1GB 800mhz dualGigabyte 4650HD
AMD Athlon 5200+
Gigabyte GA-M52L-S3
Gigabyte 4650HD
Creative Sound Blaster Audigy SE (SB0570)
Flatron Wide LG L194WT-SF
Hitachi SATA 500GB
Hitachi SATA 120GB
Shinobi Black
Yup, and they even have 64bit and 32bit as of late. Very good sound, it's what I use and I've never been happier.
Windows 7, LinuxAMD Phemon II x2 3@37501G Crucial 16668800GT OC (custom OC)
Windows 7, Linux
ASRock M3A770DE
1G Crucial 1666
Sound Blaster Live! (never changes!)
Vivitron 22"
1600x1200
Western Digital 120G/160G SATA
Maxtor 80G IDE
450w
Unknown
Custom Air cooled
Logitech M-BZ15A Laser
Cable 10mbit
so...i wanna remove 1gb of RAM right????
so that i can use it properly without crashing??
what is OS??
what is OS??
kX Project: Knowledgebase: kX Soundblaster Compatibility List
[B]Partially Supported[/B]
   [B]Card name:[/B]
Soundblaster Live! 5.1             SB022x
Google KX Drivers, they are a godsend for certain creative cards. Yours is partially supported, but I'm guessing stereo should work crystal clear. I don't know if you are wanting 5.1, but it might be working just see what happens.
Windows 7, Linux
ASRock M3A770DE
1G Crucial 1666
Vivitron 22"
1600x1200
Maxtor 80G IDE
450w
Unknown
Custom Air cooled
Cable 10mbit
er.... sorry can give the download link???
what is OS??
what is OS??
Actually the updated drivers from Creative simply do not work,...as per usual with Creative support. I consider non functioning drivers the same thing as having zero support. :sarc:
In fact the only ones that work and have creative support are the ones made by Daniel K, but creative forced him to take out all the sound adjusting functions making them nearly worthless in my opinion. Once again, zero support.
I've been doing this a long time, been there done that, years ago in fact, back when Vista first came out and as per usual once again had zero support for my Audigy 2ZS. If not for Daniel K. we would all still be in that boat, I remember the entire blow out at the creative forums and witnessed it all live. So you can probably spare on the history about these drivers. I know all about it.
In the mean time I'am using the torrent I found hosted by Daniel K. These drivers work perfectly and also have full function on all sound adjustments, EQ everything working flawlessly. Perhaps you weren't aware of this fact?
Most of his drivers can be found in the non stripped down versions by looking for the torrent. The ones you posted are some BS generic stripped down Daniel K drivers which are the only ones that Creative would let him post on their site.
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
it still not working just old drivers are workng and front speakers giveing sound but mic is working its ok wtih kx drivers mic not working and just center speaker giveing sound
what a ashame need to be a good company creative but look cant write easy driver for it
i have SB0220 and i sent email to creative and they wrote me use older version of ur operation system .They try to say creative company cant write a new drivers for windows 7 our old products are not supporting windows 7 im asking this question is it a new game ? new sound technologys for one operation system ok if it will be at windows vista i can accept vista problems but windows 7 ??? i dont think its a problem for it how it can be my audio card is not supporting windows 7 profeesssioan sound effects what a stupid idea... and still not any driver is working good for windows 7
İ think creative trying to say we are so bad company and cant support one our product just we need to write on new driver but we are so lazy we like to earn money but we dont like to support...
windows 7
windows 7
i need windows 7 driver for creative sb0220 & i can not find it any where,,and windows 7 does not detect my sound card as well ,,can some 1 please help me.....
windows 7 32 bit
windows 7 32 bit
We seen your thread, please do not spam the forum. we will help you when we can figure out the problem.
Windows 8.1 Pro x64Intel Core i5-4570 CPU @ 3.20GHz8GB DDR3-1596 - Dual ChannelNVIDIA GeForce GTX 750 Ti SC
Windows 8.1 Pro x64
Gigabyte Z87-D3HP-CF
Onboard
Samsung
SSD - 120GB
Second - 1TB
Hi
i have got the same sound Card a creative sound blaster 5.1 works brilliantly with XP & have hap it for many years, as soon as I tried SB Live! series Support Pack 1.5 (08/09/2009) with windows 7 Home premium It CRASHED big time so to all you poor souls with creative sound blaster 5.1 cards we are doomed to either throw them out & to buy New all because the sound card is OLD in this day & age that is tragic. A great working bit of kit is now defunked :( im off to buy a usb device:cry:cry:
Windows XP Pro 64
Windows XP Pro 64
