Windows 7: Realtek Sound crackling problem
04 Feb 2016   #1
jumpmouse
Windows 7 Ultimate 32bit
Hey everyone, i got this laptop:
And now.. the crackling problem, when i installed Win7, audio drivers installed automatically and crackling appears when i play a song in winamp and then scroll up and down in a folder full of pictures or scroll a site with pictures and gifs, when i play a video on youtube, when i stream a video from any other site etc.
Tried DPC Latency checker, it had green bars even when crackling appears, red bar appeared maybe once or twice after some time. Sound crackling also appears when i use headphones.
But when i install Realtek driver, it sounds way worse, like this:
https://www.youtube.com/watch?v=qd5CWVEvx0A
(Not my video)
Asus site does not have support for this laptop:
ASUS Notebook Pro55 Series Drivers Download for Windows 7, 8.1, 10 & XP
Task Manager shows this:
Aida64 Extreme shows this:
Dxdiag shows this:
I noticed that Dxdiag shows that laptop model is F5SL (?) i checked the Asus site it also does not support Win7, it looks like my laptop only the camera part is not the same.
I tried to run a bootable Ubuntu from my usb, sound works perfect, today i gave up and installed Windows XP and i installed an audio driver from Asus site, for a laptop Asus Pro55SR, and it works perfectly.
Someone said to me that the problem is in power management of the Realtek sound chip, i tried to do it but i could not find the option in the Registry Editor.
Also, when i install the correct graphics driver, on Win7 showed that it was 256mb and worked perfect, but now on XP in desktop properties it shows 512mb and i have an option for a slightly bigger resolution, and i experience screen tearing when i play a video on Media Player Classic.
But leave the graphics issue, audio matters to me most, so please help, i will try to install Windows7 again if you can find me a solution.
05 Feb 2016   #2
ICIT2LOL
Jumpmouse mate try running this ditty of mine find the audio device and download the driver for it from the manufacturers site. Anyway just find it and we can see if we can work it out. See the pic of my machine (similar to my current work lappy) I am on right now.
Using HW Info
PART A:
You can test the volts on the PSU with HW Info HWiNFO, HWiNFO32/64 - Download < download the right bit version and close the right hand window select Sensors and scroll down to the power section where you will see what the volts are doing see my pic. In my pic the section (Nuvoton) with VBATT is a dead give away you are in the section for the rail voltages. There are other section titles and one that pops up often is ITE
Now the voltage on the different rails have to be within 5% =+/- of what is required or the machine will not work properly if at all.
See this for the rail voltage info
Power Supply 101: A Reference Of Specifications - Power Supplies (Section 2.)
The original right hand window shows the machine running and is handy for that but for looking at the components in some detail close it and use the main left hand side panel
FOR OTHER COMPONENTS
PART B:
Open each small square with + in it on the section the components are in and then click on the individual component/s (it will highlight in blue) - in the right hand side will appear all sorts of details including brands speeds and other essential info that particular device. See pic for example.
Use PART B:
05 Feb 2016   #3
ICIT2LOL
JM mate in addition to my last post look around for your local Asus Service Centre and ask them directly because I cannot find that machine either not even close
06 Feb 2016   #4
jumpmouse
I tried running that program in WinXP which i'm currently using on this laptop, it looks different, and shows the same info i already got from Aida64 Extreme, as you can see in the pictures in the previous posts.
Tried contacting Realtek, no response, tried contacting Asus, they asked for a serial number of the product, i sent them pictures with the stickers which i posted here, no response.
06 Feb 2016   #5
ICIT2LOL
Yep typical of Asus support mate the local service centres are the best to deal with as I found when setting up a ROG laptop a while ago.
Look one thing you could try is this https://www.slimwareutilities.com/slimdrivers.php < just make sure you only download the drivers software as if you are not careful it will include utilities crap as well. I use it from time to time and it does use genuine sites ie Intel for example, and I always uninstall it afterwards because it is a nagger. You might get lucky with that audio driver hopefully.
Sound crackling and distortion, Asus P8Z68-V, Realtek and SB X-Fi Ti
Hello, first I would like to say that I have searched lots of threads about sound distortion, crackling or bad quality and haven't found any solution. Specs of my computer are: MB: Asus P8Z68-V CPU: Intel i5 2500k GPU: GIGABYTE N570OC-13I PS: Corsair HX650W Windows 7 Professional 64-bit ...
Realtek onboard sound card: Static/Crackling noises
Hey, I recent put together this new rig. I'm using the onboard sound card for my Gigabyte GA-X58A-UD3R Rev 2.0 mobo. The sound chipset is Realtek ALC889. I've updated the latest drivers, but there is crackling/static noise when I play music. Currently I mainly use a 2.1 speaker system. But...
[Sound crackling ] VPN client messed up my sound settings
Hi folks, Recently I was setting up a VPN client (PacketIX), and the setup wizard suggested some Audio/Video Streaming "Optimization" tweaks. I didn't pay attention and confirmed. Since then, I often hear some crackling / popping noises. For instance, this systematically occurs when I...
Crackling, static w/ Realtek onboard after switching to Win 7
I recently upgraded my computer and moved all the components to a new case and later switched to windows 7. While I was on my old OS, vista, with same hardware as I have today, I had no issues with my sound. Then I upgraded to windows 7 (clean install). I downloaded the latest Realtek...
Windows 7 Realtek crackling/popping sounds.
I get crackling/popping sounds it my games. It's very annoying because it also affect my fps. I tried different driver version and different audio settings but no luck. I notice that it all started after I installed Battlefield Bad Company 2, after I installed my new video card (ATI Radeon HD 5770)...
Sound problem with Realtek
Hello everyone, I have just installed windows 7 and I have problems with getting sound. I have "asuss p5ld2 se" board and ACL662 ( not sure about it ) sound in it. I have tryed installing newest driver from realtek no success, tryed older drivers 2.14 does not install. In device manager I find...
