Windows 7: Audio driver/Sound card issue
04 Feb 2016   #1
DeZolance
I have an issue with my audio driver which probably comes from my motherboard's sound card (Asus M5A97 PLUS)
This happens almost everyday.At any time my pc audio and mic just cuts off,if I try to turn it back on by unpluging and pluging back in my headphones or mute and unmute from my audio mixer I get a constant ear screeching static noise.
The only way I can fix it is by switching my audio type from stereo to quadroponic and it is back to normal,but either couple of hours later or the next day the audio will cut off again.The mic just stays dead if it cuts off untill it fixes it's self.
Ocassionaly the whole audio driver will crash,afterwards I would have to restart my pc to fix it,but after I reboot,my audio driver has uninstalled it's self from my pc and I have no sound or mic at all.Then of course I just have to download and install the realtek hd audio driver.Sadly after the sound driver finishes installing and I reboot my pc there still isn't any sound so I just have to repeat the process until the sound is running again.And finally,everything is back to normal no problems same as always,but it's just a matter of time when it will cut off again so the cycle repeats.
(It can't be from my headphones(Razer Tiamat 2.2) because I tested them on a different pc and they were running perfectly)
Is it a problem with my motherboard's sound card?Because I have reinstalled my windows operating system once and this issue still occurs.
Side note:
Don't even try to encourage me to contact my motherboard manufacturer because Asus still hasn't responded to my e-mail witch I sent 2 months ago on the absolute same subject.(With that email I gave them my receipt purchase of the board and it's serial number)
05 Feb 2016   #2
fireberd
To determine whether its the sound card driver or some other problem, go to the Device Manager, Sound, Video and Game Controllers section. Right click on the entry for the sound card device (Realtek) to highlight it and then LEFT click "Uninstall". Also Uninstall the driver. Restart the PC and when Windows starts it will detect the sound and should install the generic, basic function, High Definition Audio device/driver. Check to see if you have the same problem. If not, install the latest Realtek version.
Latest Realtek HD Audio Driver Version
If you still have the problem with the generic High Definition audio driver then the problem is not the Realtek driver. You can reinstall the Realtek and start looking elsewhere for the problem.
05 Feb 2016   #3
DeZolance
It did not help but thank you anyway I might just take it to a pc service center and see what could be done there
Using PC audio card for playstation 3 sound...wow..just wow.
I recently purchased a sound card which has digital optical in and out. Once installed, I tinkered around with the options and realized that I can input sound source from a gaming console...so off to the store I went in search of a descent optical cable. I decided on a 2 meter one since I always...
Chillout Room
What ext video card takes SPDIF audio from ext sound card?
Presently I have to use onboard sound card to have audio through HDMI output from video card. The external sound card installed is Xonar DG and it comes with SPDIF output header to be interfaced with video card. But I do not see no such header on the video card. I wonder what video card has such an...
Graphic Cards
Sound Blaster X-Fi Titanium Sound card issue
I have put the sound card into my computer and made sure that I've hooked up everything correctly, but I have ran into a problem with it. When I ran the download "Product Identification Module Update" from the Creative website, it's telling me that I don't have the right OS, and tells me to update...
Creative Sound card driver issue
Hello, I have been trying to get my sound card (Creative X-FI SB0460) to work under windows 7 x64, i have followed both a standard method of installation and the "Have disk" installation both failed, the "have disk" method reports it found driver but encountered an error then, fails with a "code...
Asking :SOUND DRIVER High Definition Audio Device Driver
im using now a sound driver default "High Definition Audio Device"Driver do i need to uninstall it first before changing to realtek sound drivers?? and how do i uninstall it in safest way??and was there an option to undo if something goes wrong?? im using windows 7 ultimate 32bit. ..:rolleyes:
Sound card driver issue?
After upgrading to 7 I have been experiencing some random difficulties with my sound system. When going to my sound card properties, I notice that there is a generic name to the device, "High-Definition Audio Device". Before I upgraded (when I was on Vista) I'm sure that it said Realtek-something...
Drivers
