4.1 surround sound help
  1. Posts : 535
    Windows 7 Pro 64bit
    i have a 4.1 surround sound system on my Xfi card, my sub woofer is attached to my front speakers, and i wanted to know if anyone here knows how to dedicate all bass to one pair of speakers, that way i dont get such great bass from one side during my gaming, and a horrible bass from the other with no sub.
  2. Posts : 535
    Windows 7 Pro 64bit
    http://img.photobucket.com/albums/v3...852/images.jpg
    there is a rough put together of my system
  3. Posts : 535
    Windows 7 Pro 64bit
    any help?
  4. Posts : 6,879
    Win 7 Ultimate x64
    With your speakers setup like that (a 2.1 with a 2.0) the only thing I can see assuming you have it installed (if you used the daniel_k package you should), is to play around with the THX Console,
    and see if you can get it to work the way you're looking too.
  5. Posts : 535
    Windows 7 Pro 64bit
    where can i find these drivers? :P i cant seem to find em easily
    also i don't know which ones i would need for it to work right :| .... if you know can you like me up?
  6. Posts : 535
    Windows 7 Pro 64bit
    sorry found the support 2.0 driver and will try it out
  7. Posts : 535
    Windows 7 Pro 64bit
    i have a new problem where it says "the current audio device is not supported" but is is! im goign to try a reinstall of the old driver and then installing the new stuff over it instead of wiping like i did last time
  8. Posts : 535
    Windows 7 Pro 64bit
    wow im having an impossible time, something went amuck and i could not install any drier,s so i had to use a restore point before i even used the driver pack. now its all ok but the CCL doesnt work... i will try one more time to install the support pack then yeah.
  9. Posts : 535
    Windows 7 Pro 64bit
    ok i have it installed, bit it doesn't seem to be any help it doesn't allow me to direct all my bass slow to just my front speakers. it would be simple to do too, i would code it in myself.. if i knew how
  10. Posts : 25
    win 7 32-bit
    Sweet post. I grabbed this sub today and tomorrow I'm gonna grab the two satellites. I have another set of Altec Lansing speakers that I want to run as rear, and keep a speaker bar on my monitor as a center.
    Would the setup you listed work?
