Windows 7 Forums Search
Windows 7 - 4.1 surround sound help
11-15-2009   #1
i have a 4.1 surround sound system on my Xfi card, my sub woofer is attached to my front speakers, and i wanted to know if anyone here knows how to dedicate all bass to one pair of speakers, that way i dont get such great bass from one side during my gaming, and a horrible bass from the other with no sub.
11-15-2009   #2
http://img.photobucket.com/albums/v3...852/images.jpg
there is a rough put together of my system
11-16-2009   #3
any help?
11-16-2009   #4
Win 7 Ultimate x64
With your speakers setup like that (a 2.1 with a 2.0) the only thing I can see assuming you have it installed (if you used the daniel_k package you should), is to play around with the THX Console,
and see if you can get it to work the way you're looking too.
11-16-2009   #5
Quote   Quote: Originally Posted by stormy13 View Post
Attachment 37103
where can i find these drivers? :P i cant seem to find em easily
also i don't know which ones i would need for it to work right :| .... if you know can you like me up?
11-16-2009   #6
sorry found the support 2.0 driver and will try it out
11-16-2009   #7
i have a new problem where it says "the current audio device is not supported" but is is! im goign to try a reinstall of the old driver and then installing the new stuff over it instead of wiping like i did last time
11-16-2009   #8
wow im having an impossible time, something went amuck and i could not install any drier,s so i had to use a restore point before i even used the driver pack. now its all ok but the CCL doesnt work... i will try one more time to install the support pack then yeah.
11-16-2009   #9
ok i have it installed, bit it doesn't seem to be any help it doesn't allow me to direct all my bass slow to just my front speakers. it would be simple to do too, i would code it in myself.. if i knew how
11-19-2009   #10
win 7 32-bit
Quote   Quote: Originally Posted by cloud8521 View Post
Sweet post. I grabbed this sub today and tomorrow I'm gonna grab the two satellites. I have another set of Altec Lansing speakers that I want to run as rear, and keep a speaker bar on my monitor as a center.
Would the setup you listed work?
 4.1 surround sound help problems?
Similar Threads for: 4.1 surround sound help
Surround Sound + Realtek Sound & Audio
5.1 Surround Sound Problem Sound & Audio
Help with Surround Sound Sound & Audio
Surround sound Media Center
5.1 surround sound help Sound & Audio
