problems with pausing media player/itunes
  1. Posts : 3
    windows 7 32-bit
    In windows 7, if I pause itunes or media player for more than just a few seconds, the programs no longer play audio, or worse, become unresponsive. I never had this problem before upgrading to 7 (from xp).
    Also, sometimes audio inexplicably cuts out for several seconds. This is usually a one-time thing, but is extrememly annoying nonetheless. Please help!
    (My computer is specifically set up for running audio-- a digital audio workstation).
    Thanks!
  2. Posts : 28,845
    Win 8 Release candidate 8400
    Thanks!
    Hi sammy and welcome
    We could be alot more helpful if we knew what kind of hardware you have. can you fill in your system specs in the lower left corner of your posts
    Thanks in advance
    Ken J+
  3. Posts : 3
    windows 7 32-bit
    Hi, my system specs have been added, thanks. (sorry about that, i should have realized i need to fill that in.)
  4. Posts : 12,012
    Do you know if you have the most recent drivers for that Edirol sound card?
  5. Posts : 3
    windows 7 32-bit
    I do have the most recent drivers, although they have yet to release a new driver for windows 7. The vista driver seems to work well enough. I doubt that is the problem, considering let's say itunes just freezes up on me after pausing, it's not just an audio problem. With Media Player, indeed if I stop the video and then try to continue from where i left off, it plays without audio.
    One more thing--sometimes videos or audio doesn't seem to play when I have another audio program running simultaneously. This has never been an issue before windows 7 either. When i shut down the program that's running, the new one will play correctly. So maybe this issue is connected to my other ones. Thanks.
