Weird sound issue
kareeem
1:24 PM
My sound runs flawlessly when i have some process going on (like disk cleanup, burning, etc.) If i have nothing going on, my sound is laggy and cracks. Anybody have an idea why?
This is on a Toshiba M45 S359 with latest audio drivers.
Windows 72ghz Pentium M2gb ddr2915 chipset
Toshiba M45 S359
2ghz Pentium M
2gb ddr2
915 chipset
100gb sata
CPU throttling is most likely cause. Can be from a bios settings or Windows software you're running.
7600.20510 x86P4 550 3.4 GHz HT running at 3.5 GHzOCZ 2 GB(2x1GB) DDR400mHz running @ 414 mHzHIS Radeon HD 3850 IceQ 3 Turbo HDMI Dual DL-...
self built
7600.20510 x86
MSI PM8M3-V (MS-7211 v1.x) Micro-ATX mainboard
HIS Radeon HD 3850 IceQ 3 Turbo HDMI Dual DL-DVI AGP
MOTU Traveler firewire studio interface 192 kHz 24 bit
22" widescreen Acer X223W LCD, 17" Compaq P75 CRT
1680x1050 and 1280x1024
SATA I x2 WD, 400 GB and 120 GB, SATA 2 WD Caviar Black 1 TB
350W generic
Cybertronpc, it glows blue
stock cpu fan, Ice-Q 3 gpu and system, many case fans
Logitch Classical Keyboard 200
Logitech Mediaplay cordless
1792/448 kbits/sec
SATA II PCI fake RAID adapter, 1 GB Readyboost, original ATI Remote Wonder (even works with WMC perfectly), Logitech Rumblepad 2 game controller x2
I thought the same thing (regarding your second remark), however the same thing happens after a fresh install with nothing running.
Where can I fix the CPU throttling in the BIOS?
edit: just to be clear, never oc the laptop.
Toshiba M45 S359
2ghz Pentium M
2gb ddr2
915 chipset
100gb sata
Here are my bios settings if it helps:
Toshiba M45 S359
2ghz Pentium M
2gb ddr2
915 chipset
100gb sata
I think in your bios it might be the "dynamically switchable" setting. Turn that off and see how it goes.
I found something related to it here and seems so.
"Dynamic CPU Frequency Mode = Dynamically switchable"
self built
7600.20510 x86
350W generic
1792/448 kbits/sec
Very interesting, I actually tried that about 20 minutes ago. I had the option stated above in the picture, "always high," and "always low." I put it on "always high" but no avail. Should i try always low?
Toshiba M45 S359
2ghz Pentium M
2gb ddr2
915 chipset
100gb sata
self built
7600.20510 x86
350W generic
1792/448 kbits/sec
I do have the latest bios (they only updated it once i believe). I'll see what it's running at now and what it runs on "always low" with Everest and post back.
Toshiba M45 S359
2ghz Pentium M
2gb ddr2
915 chipset
100gb sata
Always high:
Always low:
Everest wasn't so useful, so I used CPUZ. At first, the audio was working great with "always low" and then it went back to crackling and lagging.
I'm guessing it's a driver issue but is it fixable (this laptop is 4 years old).
Toshiba M45 S359
2ghz Pentium M
2gb ddr2
915 chipset
100gb sata
Anybody have any ideas or anybody else with a Toshiba M45 with some input.
Edit: I just helped my cousin install Win7 on his laptop and his audio works fine. The d600 is a lot older than the Toshiba M45 S359.
Toshiba M45 S359
2ghz Pentium M
2gb ddr2
915 chipset
100gb sata
So I found a way to deal with this when using my Slingbox. I launch a Youtube video and mute it and the audio is much better on my Slingplayer. If you guys have any other suggestions, please let me know.
Toshiba M45 S359
2ghz Pentium M
2gb ddr2
915 chipset
100gb sata
