Windows 7: My new headset not recording System Audio Help.
21 Feb 2016   #1
passion4tech
I use Audacity and I would use WASAPI and did not need Stereo Mix enabled with my old headset. Now with my new headset I have to use Stereo Mix, WASAPI won't work anymore, pretty weird issue to say the least. I installed Asus Realtek Driver 6.0.1.7354 I record in Mono. My mic boost is at +0.0db. I plugged in green jack in headphone port to record system audio and it does not work. I had no issue with my old headset recording system audio. Now I have an issue with this new headset. Any help woukd be appreciated. Here is the new headset I bought from Amazon. If you want to buy this headset for yourselves I highly recommend them, they sound great and mic picks up sound really well.
Amazon.com: [2015 New Version] eTopxizu ET2000 3.5mm Plug Wired Gaming Headphone with Noise Canceling & Microphone for PC Games Black Blue: Computers & Accessories
21 Feb 2016   #2
fireberd
If you want to RECORD you use the PINK mic jack for the microphone part of the headset. The GREEN Jack is the Speaker out (for connecting a headset or speakers).
A computer mic requires +5VDC to operate. Only the PINK mic jack has the +5VDC on the "Ring" connection.
21 Feb 2016   #3
passion4tech
FireBerd I already know to plug pink jack in mic port. I know to plug green jack in headphone port. That is what I did and the headset still would not record system audio. What am I doing wrong? Please Help me troubleshoot this issue.
21 Feb 2016   #4
fireberd
The apparent language translation caused me to not realize you were plugging into the correct jacks.
Have you tried the new mic on a different PC? If not, that is the first thing to do since this is a new headset/mic.
21 Feb 2016   #5
Layback Bear
Windows 7 Pro. 64/SP-1
Jack is your crystal ball still out being repaired?
22 Feb 2016   #6
passion4tech
Quote   Quote: Originally Posted by Layback Bear View Post
Now there is another issue. WASAPI does not work with this headset. So now I have to use Stereo Mix to record system audio. My new headset works with stereo mix, it does record system audio now with stereo mix but the problem is the system audio stereo mix recording volume is way too loud, I can't hear myself in the recording because the system audio recording volume is too high. I tried to turn the recording volume down for stereo mix but I still, my voice sounds almost muted. What is the problem here? Am I doing something wrong?
22 Feb 2016   #7
passion4tech
I even have my voice recording volume at max all the way up and I still sound muted when using stereo mix with this headset.
22 Feb 2016   #8
fireberd
Stereo Mix, at least on my Realtek, has a level control. Check yours.
Here is my Stereo Mix
22 Feb 2016   #9
passion4tech
If you read my previous post I said I tried lowering the stereo mix volume but I still sound muted
23 Feb 2016   #10
fireberd
I have no idea, sorry.
Static when recording as well as a new wireless headset "snow" problem
Hey guys, I made a thread a few years ago about me recording with a Plantronics 380 while using a dolby 5.1 usb soundcard to make the volume louder so people can actually hear me and getting a bit of static issues while recording as heard by the attachment I added with this post. Now recently...
Headset's microphone is not appearing on the recording devices list.
I recently bought a Philips SHM7110U/10 headset to hopefully get better audio than my laptop's current microphone while recording with Fraps. Fraps is currently using my laptop's default microphone, which can be changed by setting another microphone to the default. I read several articles on how...
Recording audio
How can I record the audio portion of a YouTube video?
Audio Recording
Hello... So, I've bought Asus K52JT-SX067V and I've got Fraps... Quickly realized it will record only sound from mic... Searched for Stereo Mix in settings, but only mic is shown (I have "show inactive devices" activated)... Installed drivers from Realtek webpage, but still same... Can anyone...
Recording Audio/ mic and system sounds...with headphones?
I have a screen recorder that records my screen and also my mic at the same time, i make videos to help with my knowledge base articles in sharepoint. I need to record my mic/ and also system sounds like if i have someone on skype and i am screen recording, i need to be able to record there audio,...
Recording audio
I tried to install Wavepad and it won't work with win7. Any suggestions for a freebie prog recorder that records free radio streams? This might be a deal breaker for me for moving back down to XP.
