Windows 7: Sound quality and volume drops down
29 Feb 2016   #1
XanFeisty
When I'm talking with someone in Skype, the sound will go down and the quality will fell. This also happens with some games. To make make the quality and the volume normal, I have to go to the properties and turn Dolby Digital Plus back on. It turns off by itself when doing any action from the ones above. Everything goes back to normal when I exit the game/end the Skype call. My drivers are all updated, I've unchecked all the items that are doing any manipulation to the speakers, such as lowering the sound on calls etc.
Sound quality crackle
hey, i have an advent 9115 laptop and have recently installed windows 7 32bit i firstly installed 64bit thinking it could handle it but experienced bad cracking from the audio with everything (video, music, windows sounds) i have a realtek high definition audio card. i have tried...
difference in sound quality?
hi could someone please tell me why is there such a massive audio quality difference between car radio and car cd player?? i mean when i put the radio on in my car you have nice bass and loudness without putting volume up to full, but when i put some music on a cd and put it on in my car i have...
Bad sound quality ( high pitched, almost acoustic sound etc.) integrat
the sound is crappier than ever. I have this quality loss for a while but now is repulsive. Ive reinstall windows 7, reinstall relatek drivers, get ones specified by my motherboad manufacturer, tried the latest ones.... put power management at high performance...etc my motherboard ASUS -...
volume goes up, and then drops back down to zero
hey guys, i need help real bad! i've tried everything, and all websites and have nothing.. Essentially I just closed my laptop last night and set it down. Today when I opened it, the volume was at zero, and when i press the volume button on my laptop to make it go up, it goes up as long as i keep...
Bad quality Sound
Hello. I have a Toshiba Laptop ( PSAE6E) with Harman/kardon speakers, I installed yesterday Windows 7. It's all fine excepting that the sound is bassless. I installled most recent audio drivers and it is still the same. Can you help me?
Bad sound quality in MC / good in WMP
mp3s that play perfectly in WMP are playing with very bad quality in media center (cracking sounds, slow downs...). I have seen people with similar issues but mostly with x64 setups. Can this be a driver problem and if so does anyone have a pointer for better audio drivers? This is really...
