Windows 7: Sound volume icon has disappeard
09 Mar 2016   #1
cinque8
Windows Vista 32 bit
Hello,
I am running Windows Vista on my HP laptop. My sound volume icon has disappeard from my row of icons on the bottom right of my screen. The icon is not among the hidden icons. I must have clicked on something by mistake and the icon was removed. Is there any way to get it back?
Thanks.
09 Mar 2016   #2
Ranger4
For Windows 7 open Control Panel, select Notification Area Icons & then look for the Volume Icon & then set it to Show Icon & Notifications. I think Vista is the same.
10 Mar 2016   #3
Anak
Win 7 Home Premium 64bit Ver 6.1.7600 Build 7601 - SP1
The volume bar shows sound but no sound through speakers.
Hi, I am pretty stumped with this one. I upgraded my office to windows 7 32bit pro. 10 computers all the same, but one of them has audio issues. When I play the sample music the volume bar shows the equalizer bouncing like it is sending out audio, but any speakers I plug into it produce no...
Low volume with new sound card(Creative Sound Blast 5.1 VX)
Hello! I got a new sound card today. Installed it, installed the drivers from the CD, plugged in the headphones and it works. But the sound levels are way to low. I raised the volume in all the places I could find, but it's still a bit low. Here's the card: Creative Sound Blaster 5.1 VX...
wlan icon and sound icon on system tray not working
Good morning experts, Please help me since I dont know what to do to solve this. This mornig I started my laptop, after a few minutes the wifi disconnected and the yellow dot showed on the wifi icon. I tried to click on the icon but nothing happened. Tried to click click clik and nothing...
Network & Sharing
Can't display Sound "Volume" icon?
I can't see the volume adjust button on the bottom of the screen (laptop). I check the system on/off for Time, volume, network, etc... and the volume one is dim (can't change from off to on). What I need to do to turn the volume on so I can adjust the sound. Thanks,
got two harddrives one disappeard
hi,I have a Dell studio 1749 and it has two harddrives (500 gb each SATA) my c: drive is fine but the second harddrive (d:) all of a sudden disappaerd.I no longer see it in windows explorer or the disk management mmc snapin even this commanddiskpart listlists only one disk diskpart rescan doesn't...
Hardware & Devices
volume Mix/sound Icon not showing.
Well, the Volume mix/ Sound icon in bottom right hand corner in the task bar, won't turn on! It is grayed out when I try to turn it on in notifications, I wish to be able to use this icon, but frankly, I can't. Please help me, I'm not that tech-y as most of you, I think you guys will show me a...
