Windows 7: Problem With 5.1 Surround Sound Output
30 Mar 2016   #1
Joe Ciaravino
Win 7 64 bit Home Premium
Windows 7 64 bit OS with Realtek integrated sound on motherboard. If I go to the Realtek application on my computer and test the speaker output, I get a correct test sound from all front, rear, center, and subwoofer speakers. However, when I play music with WM Player, iTunes, or any other application, I only get stereo sound (front pair speakers work only).
31 Mar 2016   #2
BorisTheAnimal
Windows 7 Home Premium
In the Realtek app there should be a box on the configuration page that you should be able to tick.
The box is "Speaker Fill" and when you hover over it: Speaker expansion makes stereo sound hearable to multi-channel speakers!
This is how it looks for me:
Cheers, Boris
31 Mar 2016   #3
dsperber
Quote   Quote: Originally Posted by Joe Ciaravino View Post
I know this sounds like a simple question and no disrespect, but is your source multi-channel, or stereo?
CD-audio is only 2-channel stereo, so if that's the the original source for your music then it would also be 2-channel stereo. It's understandable that 2-channel music would be played back through your two L/R fronts.
On the other hand, genuine multi-channel sound (e.g. from playing a BluRay/DVD, or from a media file with multi-channel audio) would of course be heard from all your speakers.
01 Apr 2016   #4
Joe Ciaravino
Quote   Quote: Originally Posted by BorisTheAnimal View Post
Attachment 384374
Cheers, Boris
Yes that works. Thank you.
01 Apr 2016   #5
Joe Ciaravino
Quote   Quote: Originally Posted by dsperber View Post
You have analyzed things somewhat more. When I playback some older recordings, possibly if not probably recorded in monaural, these only emit sound from the "front" speaker pair. When I now play audio (probably) recorded/reproduced in stereo, the sound emits from ALL speakers.
In any event, I am now satisfied with the results, despite the fact that I don't fully understand the process used to simulate 5.1 channel audio. I am grateful for both of your comments as well as your helpful remedies, Animal and DSPerber.
In the final analysis, my system now emits sound from all 6 speakers when playing stereo recordings..............simulated "matrix" sound, which is what I want. When playing older, monaural recordings, the sound emanates from the front speakers only. That is perfectly acceptable. When "true" surround sound is played back, I assume that it is truly reproduced from all 6 speakers, although I cannot discern whether it is "fidelity" reproduction or not.
02 Apr 2016   #6
BorisTheAnimal
Hey nice to hear you got it fixed, and am happy to help!
Cheers, Boris
14 Apr 2016   #7
anwaypasible
windows 7 home premium 64bit
there's only four ways to go about it:
1. you are simply copying & pasting the front left to the rear left - the front right to the rear right.
2. you are analzying the audio of stereo that is capable of using virtual speakers & then every time the virtual speaker gets close to either the rear left or rear right, instead of asking all the timing of the speaker & room to do the virtual speaker, you instead simply play the audio from the rear speaker.
3. you could also use the rear speakers to pull & drag on the soundwaves from the front speakers to enhance or strengthen the virtual speakers.
4. using either number 2 or 3, you could add environment effects (including re-mapping of the speaker location).
ever since consumers have been able to buy speaker systems with rear speakers, they've taken half of the phase away from the front speakers and used it for the rear speakers (thus preventing the front speakers from being able to do it while in 'surround' mode - unless those channels are discrete).
i can hear audio from behind me using two front speakers, simply depends on whether the audio file has such an fx in it or not.
i haven't played with all of the different virtual surround modes in existence, but i also know the ones i have played with don't really do 2, 3, or 4.
i also haven't heard anybody talking about systems being able to do it.
seems the headphone industry has been the only subject that gets any attention about it.
here's an audio file that plays audio from behind: https://youtu.be/fSSLQf95-Nc
Only able to use 7.1 surround Sound for audio output
Hi, I have done an upgrade with my graphics card to GTX 970 Strix so am attempting to play games again but am having trouble with sound. My front panel headphone input is broken so I now am trying to use the green output in the motherboard (P8z77-v LX). I have downloaded the latest Realtek...
Realtek onboard sound card with 5.1 surround speaker fill problem
I recently installed a new motherboard Asus Sabertooth 990FX. It has an on-board sound card "Realtek® ALC 892 8-Channel High Definition Audio CODEC". I'm using 5.1 surround speakers from creative. Speaker fill with windows update driver, or Realteks driver from Asus' website, has the same outcome. ...
Surround 5.1 problem, Only subwoofer produces sound
Hi everybody. Well i have a stereo 5.1 system by Creative, version SBS 580. When i first got the computer everything was fine, then my brother bought those headphones, so we didnt use the speakers at all. so after about 1-2 years without use i plugged them in and tried to use them. The...
Surround sound Problem
Dear All I hope someone can help, i am running windows 7 64 bit using a Gigabyte GA-P55-UD5 motherboard. i have just purchased a new Benq monitor with built in speakers and have connected it up via HDMI, this works perfectly. The problem i have is that i have just got some...
5.1 Surround Sound Problem
I have just hooked a Sony DVD Home Theater System (5 speakers + digital amplifier) to my onboard optical digital sound port on my computer. Using 'sound' through the control panel, I am able to test and hear the Realtek Digital Output in 5.1, using the encoded format of 'dolby digital'. However,...
A Different Surround Sound problem
A few days ago I had to replace my motherboard. The PCIe video card from the old system is a Radeon 4350 with HDMI (7.1 capable) which I consider to be better than the on-board Radeon 2100 in the new mobo (it's HDMI only supports 2-channel). I have the 2100 disabled in the device manager. If i...
