Windows 7: Audio Output from Monitor Buzzing Noise Problem!
16 Apr 2016   #11
passion4tech
The monitor is the culprit here guys. Is my monitor's audio output defective? Sometimes when I scroll the wheel on my mouse I hear another noise through the speakers connected to the monitor audio output
16 Apr 2016   #12
anwaypasible
windows 7 home premium 64bit
did you test the speakers to see if they aren't injecting electricity into your monitor?
when there's an electrical problem, things don't always simply work as if there's a low battery.
haven't you ever seen a movie where something electrical was broken & there was little miniature lightning coming from something?
17 Apr 2016   #13
Mellon Head
Quote   Quote: Originally Posted by passion4tech View Post
I made sure the green audio cable is plugged all the way in monitor's audio output and it still makes buzzing noise. Listen to it for yourself. It is really annoying noise. I am 100% sure there is nothing wrong with my Acer H257HU Monitor.
How is the audio signal getting to the monitor? Is it via HDMI? If so, check that the HDMI connectors are plugged in properly on both the graphics card and the monitor. That may be the culprit.
Also, what happens when you plug the audio connection directly into the computer's speaker jack? Do you still get the hum?
17 Apr 2016   #14
passion4tech
Quote   Quote: Originally Posted by Mellon Head View Post
I use DVI. My H257HU monitor is display connected to computer via DVI. The monitor is connected to computer audio via green audio cable. I plugged the green audio cable from computer audio output to monitor's audio input. When I plug audio connection directly into computers speaker jack I don't hear buzzing noise at all which is good
17 Apr 2016   #15
Mellon Head
Hmmm. It might be that the monitor has a problem in its audio circuitry, but a more likely possibility is that you have a flaky green cable going from the PC to the monitor, as fireberd suggested. If you want to use the monitor output to drive your speakers, the thing to do would be to try a new cable between the PC and the monitor to see if the buzzing goes away.
But if it works for you, you could always just use the speaker output jack on the PC and plug the speakers into that. As you say, it causes no buzzing when you do that. That might be the simplest solution of all.
17 Apr 2016   #16
passion4tech
It's definitely an audio circuitry problem with the monitor. I tried a different audio cable and I still heard the buzzing noise
17 Apr 2016   #17
Mellon Head
That's too bad. I guess your only option for buzz-free audio is to plug the speakers directly into the PC's audio output.
17 Apr 2016   #18
passion4tech
OK so should I send my monitor in for repair or not?
17 Apr 2016   #19
Mellon Head
Well, if the audio jack in the monitor is important to you, then sure, but then can you really be without your monitor for a couple of weeks or more?
If it's not that important, I wouldn't worry about fixing it myself, if I'm not going to use the feature.
I guess it's really up to you and whether it's worth it or not to you. Me, I wouldn't bother.
17 Apr 2016   #20
passion4tech
So I guess I shouldn't send my monitor to Acer Repair because I would have to wait a long time. I use DVI because I use this kinivo 5 hdmi switch device to add more hdmi ports to my H257HU. I use my H257HU as a monitor and a tv. I have a wii u and directv box connected to kinivo 5 hdmi switch. The audio jack in the monitor is important to me, I like to use the monitor audio output.
Buzzing noise from the tower
Hi all, back to the gurus!! Just tried to convert a few movies to AVI, using Freemake video converter. Gets to around 5% and then I get a buzzing sound emanating from the tower. Didn't sound like a fan hum or the like, a bzzzzz like a loud mozzie. Disconnected everything, took off the side cover...
General Discussion
Realtek HD Audio Manager, Buzzing noise in playback
I've got a headset with a mic and In the Audio Manager i've got the playback volume muted. When i un-mute it there is a faint buzzing noise. thats not a big problem but when i want to talk to friends on skype. I'm really quiet and they can hear the buzzing noise. When I try to use the Microphone...
Computer monitor shuts down. And audio loops, causing buzzing noise.
Something strange happened to me today (well the day I posted this thread). I was watching this: "https://www.youtube.com/watch?v=Qj6Kg94vPEw" My laptop monitor broke one day so I had to connect a external monitor. The laptop monitor is plain black and doesnt work 100 (and 1)% of the time. Anyways...
General Discussion
Buzzing on audio output and loss of mouse/keyboard:can't shut down
Suddenly after starting the computer and going online there was a loud buzz on my stereo output. The output goes from my optical audio. This has never happened before. I flipped the receiver to radio and it's fine. Typing on my backup computer now. The sound from this computer to a different input...
Hardware & Devices
xonar d2x sound card loud buzzing noise problem
I am using xonar d2x sound card and it has been good until recently when I played videos on youtube and games it gives a loud buzzing noise. Even sounds made by windows sound produces the loud buzzing noise. It also happens on sometimes when playing videos. Other than that it works fine. I tried to...
Buzzing noise?
a week ago, my dell started making a high pitched buzzing noise from the mobo, any idea why it would do that? i have not been rough with it at all.
General Discussion
