Windows 7: Audio Output from Monitor Buzzing Noise Problem!
17 Apr 2016   #21
Mellon Head
Quote   Quote: Originally Posted by passion4tech View Post
So I guess I shouldn't send my monitor to Acer Repair because I would have to wait a long time. I use DVI because I use this kinivo 5 hdmi switch device to add more hdmi ports to my H257HU. I use my H257HU as a monitor and a tv. I have a wii u and directv box connected to kinivo 5 hdmi switch. The audio jack in the monitor is important to me, I like to use the monitor audio output.
Well, all I can say is if the audio jack is important to you, and it looks like it is based on how you use the monitor, then you should have it fixed.
Does the audio buzz with all input sources, or just the computer?
17 Apr 2016   #22
passion4tech
Quote   Quote: Originally Posted by Mellon Head View Post
The audio buzz only happens with just computer.
18 Apr 2016   #23
fireberd
The audio "output" from the monitor would probably be just a "pass through". However, internally in the monitor it may not be properly shielded and even have a missing ground. Best option, as noted is to run the speakers directly from the PC. Adding the monitor into the circuit is "complicating the ham sandwich" and other than possibly a shorter connection to your speakers doesn't buy you anything except a potential (real) trouble.
18 Apr 2016   #24
passion4tech
So fireberd do you think I should send my H257HU to Acer Repair?
19 Apr 2016   #25
fireberd
What does connecting to the monitor instead of directly to the PC get you? Is there a volume control on the monitor that you use? or just convenience of connecting the speakers to it? If its just the convenience, get a long "headset" extension cable, connect that to the PC and then run that up on your desk and connect the speakers to the extension cable.
If there is some amplification and a volume control on the monitor and you take advantage of that, then consider getting it repaired (if it can be repaired - the price to repair it may be cost prohibitive compared to buying a new one).
09 Jun 2016   #26
passion4tech
Hello It's been a while ok, so I got my monitor repaired and I received a brand new monitor from acer repair which took almost 2 months long story short. But guess what guys, I still hear the same buzzing noise with this same new monitor replacement I have no idea why this grounding shielding buzzing noise is happening? Did I receive two lemons in a row bad luck or does this happen with all the acer monitor that I have? Is this normal?
Buzzing noise from the tower
Hi all, back to the gurus!! Just tried to convert a few movies to AVI, using Freemake video converter. Gets to around 5% and then I get a buzzing sound emanating from the tower. Didn't sound like a fan hum or the like, a bzzzzz like a loud mozzie. Disconnected everything, took off the side cover...
General Discussion
Realtek HD Audio Manager, Buzzing noise in playback
I've got a headset with a mic and In the Audio Manager i've got the playback volume muted. When i un-mute it there is a faint buzzing noise. thats not a big problem but when i want to talk to friends on skype. I'm really quiet and they can hear the buzzing noise. When I try to use the Microphone...
Computer monitor shuts down. And audio loops, causing buzzing noise.
Something strange happened to me today (well the day I posted this thread). I was watching this: "https://www.youtube.com/watch?v=Qj6Kg94vPEw" My laptop monitor broke one day so I had to connect a external monitor. The laptop monitor is plain black and doesnt work 100 (and 1)% of the time. Anyways...
General Discussion
Buzzing on audio output and loss of mouse/keyboard:can't shut down
Suddenly after starting the computer and going online there was a loud buzz on my stereo output. The output goes from my optical audio. This has never happened before. I flipped the receiver to radio and it's fine. Typing on my backup computer now. The sound from this computer to a different input...
Hardware & Devices
xonar d2x sound card loud buzzing noise problem
I am using xonar d2x sound card and it has been good until recently when I played videos on youtube and games it gives a loud buzzing noise. Even sounds made by windows sound produces the loud buzzing noise. It also happens on sometimes when playing videos. Other than that it works fine. I tried to...
Buzzing noise?
a week ago, my dell started making a high pitched buzzing noise from the mobo, any idea why it would do that? i have not been rough with it at all.
General Discussion
