Windows 7: HP Pavilion DV9700, no audio output device installed
27 Apr 2016   #1
jdd89
Windows 7 Home Edition 64 Bit
Hi everyone,
I recently updated a friends laptop (HP Pavilion DV9700) from Windows Vista to Windows 7 and there has been no audio since the upgrade. I know the sound card is good, since it worked before upgrading. I have searched the HP Driver and Support webpage, but unfortunately all of the drivers are Windows Vista only and do not work on the computer (no effect) It asks me to restart and upon restarting there is still a white X within a red circle on the speaker logo in the system tray. I have been scouring Google and have tried installing the HP support tool, adding legacy hardware, installed Realtek drivers, installed the HP Vista drivers, among several others. I have been working on this for well over 6 hours, banging my head against the wall...... This is a clean install of windows 7 home 64 bit. If I hover over the icon it states "No audio output device installed."
I am exhausted at trying to figure this out. Please it you have any advise I will appreciate it.
Thank you
-Jon
27 Apr 2016   #2
ICIT2LOL
Jon read this ditty of mine and use PART B: to look at the components and see if there is an audio device listed in it
Using HW Info
PART A:
You can test the volts on the PSU with HW Info HWiNFO, HWiNFO32/64 - Download < download the right bit version and close the right hand window select Sensors and scroll down to the power section where you will see what the volts are doing see my pic. In my pic the section (Nuvoton) with VBATT is a dead give away you are in the section for the rail voltages. There are other section titles and one that pops up often is ITE
Now the voltage on the different rails have to be within 5% =+/- of what is required or the machine will not work properly if at all.
Limits +/-
12v = 11.4 – 12.6v
5v = 4.74 – 5.25v
3.3v = 3.135 – 3.465v
The Power good signal voltage at pin 8 on the 24 pin plug (grey cable) should be the same as the 5v rail reading/s
See this for the rail voltage info
Power Supply 101: A Reference Of Specifications - Power Supplies (Section 2.)
The original right hand window shows the machine running and is handy for that but for looking at the components in some detail close it and use the main left hand side panel
FOR OTHER COMPONENTS
PART B:
Open each small square with + in it on the section the components are in and then click on the individual component/s (it will highlight in blue) - in the right hand side will appear all sorts of details including brands speeds and other essential info that particular device. See pic for example.
My pic is of my main laptop but just highlight the individual devices and in the right hand window will appear very detailed info on that highlighted device
27 Apr 2016   #3
oscer1
win 7 64 bit
List the hardware id's
Open the Device Manager
Right Click on the Device in question
Properties
Details Tab
In XP the VEN_ #### and DEV_ #### is located under Device Instance ID
In Vista and Win7 the VEN_ #### and DEV_#### is located under Hardware ID
Also check bios and make sure audio is enabled
27 Apr 2016   #4
jdd89
Hi ICIT2LOL.
I installed HWiNFO 64 bit, and within the audio section (pressing the +) it says "unknown or none." Within device manager there is nothing to be found. There are a few that state Base System Device (see below for hardware Id's), a co-processor, and an unknown device. I installed the chipset driver, video driver, ethernet driver, and sound driver in that order, however I could only download the Vista version since they do not make a Windows 7 version. I am beginning to believe that some of this hardware is not Windows 7 compatible. I can usually download Driver Booster from Iobit and it automatically finds everything, but this is not the case. If I didn't know whether or not it was broken prior to the upgrade I would have questioned the integrity of the sound card, but the odds of the sound card going out at the installation of Windows 7 sounds to me like a software issue.
Base System #1 PCI\VEN_1180&DEV_0843&SUBSYS_30CF103C&REV_12
PCI\VEN_1180&DEV_0843&CC_088000
Base System #2 PCI\VEN_1180&DEV_0852&SUBSYS_30CF103C&REV_12
PCI\VEN_1180&DEV_0852&CC_088000
Base System #3 PCI\VEN_1180&DEV_0592&SUBSYS_30CF103C&REV_12
PCI\VEN_1180&DEV_0592&CC_088000
Coprocessor PCI\VEN_1180&DEV_0543&SUBSYS_30CF103C&REV_12
PCI\VEN_1180&DEV_0543&CC_088000
Unknown Device ACPI\HPQ0007
*HPQ0007
Thanks again for your help.
-Jon
27 Apr 2016   #5
oscer1
win 7 64 bit
the unknown device looks to be the quick launch button driver. ACPI HPQ0006 HPQ0007 driver for Windows 7 (download)
29 Apr 2016   #6
erpster4
Windows 7 SP1 Home Premium 64bit [x64]
jdd89, check in Device Manager, expand the System devices section and look for the High Definition Audio Controller device. If that is there, then the Realtek HD audio device should work (unless it's disabled in the BIOS). If it is not there, then there's a problem with the HD audio controller itself (and the Realtek audio device won't show up in Device manager at all).
I sort of had this problem on an HP Pavilion A6110N desktop computer where the High Definition Audio Controller device does not show up when I turn on the computer and the Realtek HD audio driver cannot load (and thus the "No Audio Output Device is Installed" message shows up). Turns out the High Definition Audio Controller device driver (hdaudbus.sys) for my Realtek audio device is sharing IRQ23 with the Standard Enhanced PCI to USB Host Controller device and its driver (usbehci.sys) is also using IRQ23 and the onboard nVidia Geforce 6150SE device (using device driver nvlddmkm.sys) is also using IRQ23. Like dang, 3 devices sharing a single IRQ - one or more of these devices won't work. What I did was remove the Standard Enhanced USB Controller and the Standard Openhcd USB Host Controller devices in Device Manager, rebooted and went into BIOS setup to disable some unnecessary hardware (like the 1394 firewire & built-in LAN) which freed up some IRQ resources, set the onboard audio controller to Enabled instead of Auto, exited BIOS and reloaded Win7. Win7 reinstalled the Standard EHCI Controller and reassigned the IRQ to 22 instead of 23, the High Definition Audio Controller device also reassigned the IRQ resource to 22 and the Geforce 6150se and Standard OHCI Controller are the only two devices using IRQ23.
In other words, it was a combination of a hardware & software problem (aka IRQ sharing problem & perhaps one of those drivers loading out of order); granted this problem was on a desktop computer, not at laptop.
I did however upgrade my cousin's HP Pavilion DV6648SE home entertainment laptop PC from Vista to Win7 (a 32bit version) earlier this year and the onboard Realtek audio ALC268 worked fine on Win7 [I had installed v6.0.1.7707 of the driver] but the Win7 OS was giving a battery warning "Consider replacing your battery" message which I did not encounter on Vista. When I ran BatteryInfoView on the HP dv6648se laptop, the battery "wear level" was 34.5% meaning it was time to replace the laptop battery, which I did. Ordering & installing a replacement battery eliminated the battery warning message in Win7. My cousin bought that HP laptop sometime in 2008.
By the way, PCI\VEN_1180&DEV_0592, PCI\VEN_1180&DEV_0852 & PCI\VEN_1180&DEV_0843 seem to be Ricoh card reader devices. Obtain the latest Win7 compatible Ricoh card reader drivers from Microsoft Update Catalog (use IE to access that web site), which I did with my cousin's HP dv6648se laptop. You will have to use Device Manager to install the Ricoh card reader controller drivers.
No Audio Output Device is installed, HDMI Audio Out Works
No sound. Little speaker with the red 'x' appeared yesterday I have gone through the whole update drivers circus to no avail, my laptop can't detect that it has speakers built in so it doesn't bother finding a driver for them. This is where I am at: - Intel Display Audio is the only driver...
No audio output device installed...Tried everything, need some help.
All fixed...Hardware issue. Stripped it down and rebuilt it. Booted up and installed the drivers....woohoo I have sound again...lol Hi, I have had this problem now for a couple of months. What I have tried: Reinstall windows 7 Update bios Install the realtek high definition audio...
Realtek Audio: No Audio Output Device is Installed
Hello. Im having the dreadful "No Audio Output Device is Installed" problem on my realtek audio. It worked some months ago, but im in no position to do a roll back. Im sure the hardware is just fine, it works with Ubuntu. The computer is a Dell Vostro 430. My OS is win7 64bit. I tried...
Hello, Can anyone help me get my onboard sound to work? Newly put together computer, and after trying drivers on CD, on Gigabyte home page, and newly posted 2.54 from Realtek site, I still have no sound. Ive tried everything I can think of driver wise, toggled BIOS option for Azalia codec...
No audio output device is installed
This is the message i am getting at the bottom of my screen so i now have no audio. I re installed windows 7 but went from 64 to 32 bit and now i have no audio. I have looked everywere to download drivers etc but no luck. I hope you can help.
No Audio Output Device Installed
I have a Benq joybook s52 and I recently installed Windows 7 Ultimate on my laptop computer. Everything is working great, but I have no sound. In the bottom right corner, I have the audio icon with a red circle and a white x. It also says 'No Audio Output Device Installed'. When I look in the...
