no problem. Glad you got it working.
I have this exact same problem. What is the power service? How do I access it?
Type services.msc in run, look for Power, if not started, right click it, Properties, set Startup type to automatic. You can access services through Task Manager as well.
I find it on another forum - easy fix, which I never would have figured out on my own. Had to right click on the blank box for sound - then "show disabled..." and voila! That's a relief. Now if I could only figure out what happened to my built in webcam, which has completely disappeared from my laptop...
hy... im new and i have a problem with my computer
i speak english bad...so i hope you understand me
i had xp installed on my computer, now i have windows 7 ultimate x64 . but i need an audio driver. it doesn't detect my headphones. i have CPU amd athlon 64 3200+, motherboard is asus ati radeon Xpress 200 crossfire. i can't find audio driver on internet. i installed a few but still no sound. the volume controler appears on the bar but i don't know what the problem is. so please help ... pm me on my messenger id subaru_vrx
please help, i have no clue to how to find my power state thingy, i would appreciate it if warlock could tell me exactly how he did it, i am running windows 7 ultimate x64 as of now. so please help me, i am vary sad that i cannot go on skype or watch movies anymore please help, this thread is my only hope.
I have been trying to fix this problem for weeks and looked all over the internet for solutions, ive tried downloading audio drivers but they dont install properly, im sick of having no sound!! someone please help!!
Windows 7 Home Premium
Acer Aspire
no-sound-error-1068-dependency-service-failed-to
Method 2:
Check the services manually.
I suggest that you check if the dependency services are started and check if you have the same issue.
a. Click Start, type Services.msc in the Start Search box.
b. Scroll down the list of services, right-click Windows Audio and select Start.
c. Select Properties for Windows Audio and set its Startup Type to Automatic.
If the Windows Audio service does not start and you get the error ‘Error 1068: The dependency service or group failed to start, then make sure that the following services are started and their Startup Type is set to Automatic’
a. Plug and Play
b. Multimedia Class Scheduler <-- in my case this was diabled
c. Windows Audio Endpoint Builder
No sound: Error: 1068-dependency service failed to start - Microsoft Community
