Solved No audio devices are installed
Warlock1
12:41 AM
Hey guys im new to this forum .I have a problem i dont have any sound.When i click on the volume icon at the bottom of my screen and go to playback it says ''No audio devices are installed''When i open the sound options there are no speakers.
When i go to services.msc and try to start audio and audio enpoint it says there is an error.I downloaded nvidia hdmi audio driver but when i open it ,it says no audio services are not downloaded something like that.Ive tried nearly everything.
Also when i go to device manager and sound there is nothing about sound it just says nvidia hdmi output.
Also i have windows 7 dual boot with windows vista and i logged in with windows vista and it is fine.
PLEASE HELP I CANT STAND HAVING NO SOUND:p
Windows 7 ultimate 32 bit
Acer Aspire R3600
Warlock Hi and welcome to sevenforums
Pretty clear you need to install the audio driver. Can you give us info about your computer mobo, audio chipset, 32bit or 64, etc
Rhanks in advance
Ken J+
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
Dwarf Dwf/11/2012 r09/2013
Windows 8.1 Pro RTM x64
ASRock Z77 Extreme4-M
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Avast! 8.0.1497
IE 11
HEy thanks for the reply.
Im using an Acer Aspire Revo 360 2 gb ram and Intel Atom 1.6ghz and running on Windows 7 32bit , G45 chipset,Nvidia ION.
I tried downloading Realtek audio but when i find it in device manager and update it says that the high definition audio device is up to date.I also tried opening the realtek setup and when i installed it it says no audio services are installed.
Acer Aspire R3600
Can someono help me because i cant survive without any sound.
Acer Aspire R3600
Can you post some shots showing the relevant sections of Device Manager both from Vista and from W7?
Gigabyte IF233
Avast! 8.0.1497
IE 11
Windows 7 Ultimate x64AMD Phenom II x48GBNVIDIA GeForce HD
Self build
AMD Phenom II x4
Gigabyte 880
8GB
NVIDIA GeForce HD
2 x 1TB
Thermalake 550w
XCase
8MB
Here are the shots.By the way i downloaded all drivers Nvidia also realtek but nothing
Acer Aspire R3600
have you disabled any services?
Make sure the Power service is started and set to Automatic
Windows 7 Ultimate x64 RTMAMD Athlon II X2 240 @ 3.2Ghz6GB Mushkin DDR3 PC-1333ATI Radeon HD 4200 IGP Hybrid CrossFireX w\ S...
Home Built
Gigabyte GA-MA785GMT-UD2H
ATI Radeon HD 4200 IGP Hybrid CrossFireX w\ Sapphire HD3450
Onboard Realtek HD audio controller
D-SUB: LG W2343T-PF 23" LCD HDMI: LG 32LH20 32" LCD
1920*1080
WD Caviar Green 1TB SATA3
Cooler Master Elite Power 400W
Cooler Master Elite 360
AMD Stock :)
Crappy wirelss logitech
crappy wireless logitech
792k
Fixed , thanks guys it was the power service it was disable .!!thanks so much
Acer Aspire R3600
no problem. Glad you got it working.
Home Built
1920*1080
AMD Stock :)
792k
Acer Aspire R3600
I have this exact same problem. What is the power service? How do I access it?
Windows Vista 32 bit
Type services.msc in run, look for Power, if not started, right click it, Properties, set Startup type to automatic. You can access services through Task Manager as well.
W7, W8.1
Dell \ Lenovo\ HP \ Toshiba
W7, W8.1
MSE, Malwarebytes
FF
fixed the sound part
I find it on another forum - easy fix, which I never would have figured out on my own. Had to right click on the blank box for sound - then "show disabled..." and voila! That's a relief. Now if I could only figure out what happened to my built in webcam, which has completely disappeared from my laptop...
hy... im new and i have a problem with my computer
i speak english bad...so i hope you understand me
i had xp installed on my computer, now i have windows 7 ultimate x64 . but i need an audio driver. it doesn't detect my headphones. i have CPU amd athlon 64 3200+, motherboard is asus ati radeon Xpress 200 crossfire. i can't find audio driver on internet. i installed a few but still no sound. the volume controler appears on the bar but i don't know what the problem is. so please help ... pm me on my messenger id subaru_vrx
windows 7 ultimate x64amd athlon 64ati radeon fx 1300
amd athlon 64
ati radeon fx 1300
dell
i have the same problem
please help, i have no clue to how to find my power state thingy, i would appreciate it if warlock could tell me exactly how he did it, i am running windows 7 ultimate x64 as of now. so please help me, i am vary sad that i cannot go on skype or watch movies anymore :cry: please help, this thread is my only hope.
Win7 Ultimate x64bit
Advent Mondena M101 NO SOUND!!1
I have been trying to fix this problem for weeks and looked all over the internet for solutions, ive tried downloading audio drivers but they dont install properly, im sick of having no sound!! someone please help!!
windows 7 64 bit
Advent Mondena M101
windows 7 64 bit
Windows 7 Home Premium
Acer Aspire
no-sound-error-1068-dependency-service-failed-to
Method 2:
Check the services manually.
I suggest that you check if the dependency services are started and check if you have the same issue.
a. Click Start, type Services.msc in the Start Search box.
b. Scroll down the list of services, right-click Windows Audio and select Start.
c. Select Properties for Windows Audio and set its Startup Type to Automatic.
If the Windows Audio service does not start and you get the error ‘Error 1068: The dependency service or group failed to start, then make sure that the following services are started and their Startup Type is set to Automatic’
a. Plug and Play
b. Multimedia Class Scheduler <-- in my case this was diabled
c. Windows Audio Endpoint Builder
No sound: Error: 1068-dependency service failed to start - Microsoft Community
Acer
