Windows 7: Mic. cuts out after a few seconds. It's not the input device.
12 May 2016   #1
satis5d
Win 7 Pro (w/ SP1) 64 bit
Recently, my desktop computer (Dell Precision r3500) started acting up. While on a Skype call the microphone would suddenly go silent after a few seconds of use. I could temporarily fix the problem by muting the mic and then unmuting it which would give me another few seconds (anywhere from 3 to 20 seconds.) Naturally, I thought it was my Logitech Webcam which I've been using as my microphone for a few years now with no previous problems. But when I disconnected the webcam and plugged a microphone into the microphone port on the front of the computer, the problem manifested in exactly the same way.
I then tested the microphone on my laptop running the same Skype application and everything worked great with that machine. The problem isn't Skype, and it isn't the input device. I've checked the drivers and everything there seems to check out okay.
Anyone got a solution? Do I need to buy a cheap sound card? Would that fix this problem?
12 May 2016   #2
fireberd
I've seen web cams interfere with mic inputs (and on the Dell forums). But, that may not be your problem. First thought, do a "refresh" of the sound. Go to the Device Manager, RIGHT click on the entry for the either the Analog Devices ADI sound device entry or if you have an optional SoundBlaster sound card then uninstall that. DO NOT uninstall the drivers. Restart the PC and when Windows starts it will detect and reinstall the sound.
13 May 2016   #3
fireberd
After re-reading your post. I changed my mind. It is most likely not a sound card problem. The USB connected audio devices are already digital so there is no need for the PC's sound card to convert it to digital (for use by the PC). Thus, if the Webcam is disconnected and you still have the problem with the mic cutting out, the problem would appear to be an application issue.
Check the mic with some other program, such as the built in Windows sound recorder. If it works OK there that eliminates the sound card and puts it back to a Skype issue.
Error: No USB KB Input Device
I installed a Superspeed USB 3.0 7-port hub since I was about out of USB ports. I moved my mouse, Wacom tablet and a Logitech portable keyboard (keyboard #2 that I use when I am using the Wacom tablet for photo editing) to the 7-port hub and plugged the hub into power and a USB 3.0 port on the W7...
Hardware & Devices
PCI Input Device - Code 28 in Device Manager
I've just upgraded my 6 year old computer from Win XP to Win 7. In Device Manager, there is an item with a yellow caution under Other Devices called "PCI Input Device". The Device Properties indicates Code 28. I searched both the Internet and the computer but couldn't find a driver. I ran...
Drivers
Input device not available
I'm trying to record something from a website. Using Audicity or Adobe Audition. However in the sound options Stereo-mix (VIA high definition audio) momentarily not available? Since the sound is functioning in playing for instance system or youtube there must be an input device? Running both...
No Audio INPUT Device
I have an Asus P6T motherboard with Realtek ALC1200 on board audio and Windows 7 64 bit OS, DirectX 10, Audio Driver version 6.0.1.5859. The sound works normally for all audio functions. I installed Nero and went to use the Wave Editor application to record a song from the web and got the...
USB input device issues
Just got a new computer running Win7Pro64. The only input devices that function properly are my Logitech G500 and a PS/2 keyboard/mouse combo from my old Compaq system. All standard USB mice & keyboards (wired or wireless) don't function properly. Keyboard Issues: A single key press randomly...
Hardware & Devices
firewire audio device cuts out randomly
well, not randomly. after a certain amount of playback in itunes, the audio stops. the music stops playing, although the play button is still pressed, the time slider will not advance. i have searched around and not seen anyone describing a similar issue, so i decided it was time to post. my system...
