Windows 7: Need Help With My Sound?
21 May 2016   #1
Yankie007
Windows 7 Home Premium 64bit.
I just bought a second monitor and when I plugged it in the HDMI behind my Desktop Computer, I lost all my sound and if I unplug it, the sound comes back! The reason I use a HDMI is because I don't have a DVI cable and there is only one spot for VGA (already used). My question is how to enable sound for both monitors?
Thanks in advance,
Yannik
Ps:
My other question is quite simple: Is it possible to purchase a wireless keyboard but still use a wire mouse?
21 May 2016   #2
fireberd
Windows automatically, as you have found out, changes the Default audio playback device from "Speakers" (PC Sound) to "HDMI" when an HDMI cable is connected. You can manually change it back to "Speakers".
I don't use HDMI so I can't verify but I was told if you disable the HDMI audio in the Device Manager that it will not switch the sound. Give that a try.
Second question. Yes, you can use a wireless keyboard with a wired mouse. Both are separate connections and functions.
21 May 2016   #3
Yankie007
Thank you so much for the help. As for the sound, I went in device manager although I can't locate what you said about disabling the HDMI audio! There is a thing called: Sound, video and game controller:
AMD High Definition Audio Device
Beat Wireless (Mono Audio)
Beat Wireless (Stereo Audio)
Creative SB X-FI
Hauppage Win
HD WebCam C525
I don't know how to disable it from there?
21 May 2016   #4
fireberd
The "AMD High Definition Audio Device" is the HDMI audio and the one to disable. RIGHT click on that entry and then LEFT click "Disable".
21 May 2016   #5
Layback Bear
Windows 7 Pro. 64/SP-1
I use external speakers and HDMI and all I do is select the speakers here as Default.
21 May 2016   #6
Yankie007
Quote   Quote: Originally Posted by Layback Bear View Post
Attachment 387005
It WORKED, thank You soooo Much and Fireberd!
Creative Sound Blaster Audigy FX Sound Card, no playback/recording
Hi, I recently purchased the Creative Sound Blaster Audigy FX and am having problems getting it to actually play any audio or record any sound. I've browsed other threads with similar issues on this board and as such have disabled my motherboards onboard audio in my BIOS settings, have...
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
narrator no sound - and sound vbs file no sound
I tried this file on my other win 7 and it works fine , but I have no sound with this file . and narrator has no sound also .. system sounds and mp3 's / movies sound good ... Ideas . thanks
Missing Sound Video & Game Controller in Device Manager, no sound
Hi Its bit complicated.:D I have 5 year old Compaq Pressario V3611AU notebook with AMD Atholon X2 TK-55 processor. Was using Windows XP and everything working fine. Recently I upgraded RAM to 2GB & processor was changed to AMD Turion(tm) X2 TL-60 2.00Ghz. I installed windows 7 and everything...
