Windows 7: HDMI monitor no speakers-no sound from anywhere when connected?
31 May 2016   #1
funnyphani
Windows 10 Home 64 bit
I have the same issue in windows 10 home 64 bit-
When I right click on the volume control, the options it shows are:
open volume control
playback devices
recording devices
sounds
volume control options
It does not give me a properties option.
Then I went to control panel and searched for sound. Then I saw the screen below. There was a Digital Audio as well and I clicked 'Don't use this device(disable)' on it by mistake and clicked OK.
Now, I only have Speakers option. How do I get the Digital Audio option back in here? I think that will solve my original problem.
01 Jun 2016   #2
fireberd
You need "HDMI Audio", not digital audio. Your video card (or CPU if you are using an Intel with integrated HDMI audio) provides the HDMI audio (in the HDMI video connection).
You failed to fill in the "My System Spec's" so we can only provide general info, not specific.
You should have either AMD OR NVIDIA High Definition Audio, or Intel audio listed in the Device Manager Sounds Section. If there is no audio, other than the standard PC audio (e.g. Realtek or whatever you have) then you will not get HDMI Audio. In the Control Panel/Hardware and Sound, Sound Panel playback, HDMI Audio should be listed and Windows will automatically switch the default audio playback device from "Speakers" (PC audio) to HDMI.
Anything additional, we need PC specs.
I have an external monitor with no speakers I use as a dual display along with my laptop monitor. No sound comes out of my laptop speakers nor when I hook up external speakers to it while I have the external monitor hooked up by the HDMI cable. Is there anything I can do to get this to work?...
No Sound via HDMI on monitor speakers??!!!!?!!
Hello guys, I bought a new monitor from LG and connected it via HDMI to my laptop but the sound does not work on the speakers of my monitor could you help me please???
No sound through speakers.Jack not being detected.HDMI sound only?
So I've got a problem,I changed my case 2 days ago and everything went great,all working as it should be.Up until an hour ago,when the lid got stuck in one of the little clips so after a quick bang it went in.But then I lost my picture on both monitors. So I went to investigate,I ended up...
no sound through tv via hdmi, sound plays through laptop speakers (idt
Yesterday I installed a new external hard drive - following the installation - my sound no longer played through my television (video is fine, HDMI connection) and sound now comes ONLY through the laptop speakers. The option for HDMI Audio doesn't appear in the 'sound' menus. I have 'checked'...
No sound to HiFi speakers when HDMI Cable Connected
Hi I have connect my laptop using an HDMI cable to my TV. And from my tv I have connected my two HiFi speakers. When the TV is on an AV channel I have sound coming from the TV and HiFi speakers but when I switch it to the HDMI source channel, sound only comes from the TV and not HiFi speakers....
Monitor Speakers not working when connected via HDMI to laptop
Hi, I've recently purchased a Samsung T23A750 monitor and to my disappointment when I try to watch a movie the built in speakers are not functioning. I have a Sony Vaio Z216GX connected via HDMI to the monitor (HDMI-DVI) port. I can definitely see the video, but no audio is playing from the...
