Sound is not in stereo
notinkeys
1:15 AM
I noticed today when trying to make some settings changes to my speaker properties that my sound is in mono, not stereo. I vaguely remember making a change a while back, but whatever I changed, I don't recall. I tried everywhere i could look to see if I could determine why the speakers were mono but nothing was evident. This is a systemwide thing, not just an app or two.
Any suggestions?
Thanks...
Windows 7 Ultimate
Windows 7 Ultimate
Control Panel>Sound right click on your device and hit Properties. Go to the Advanced tab and make sure it is 2 channel, not one.
Windows 7 Professional x64Intel i7 2600K OC'd @ 4620 MHz16GB GSkill Sniper 2133 Mhz (4x4GB)EVGA GeForce GTX 480 SuperClocked+
Asus P8Z68-V Pro
2x Acer S273HLbmii 27"
2 x 1920x1080
64GB Crucial M4 SSD
Storage: Hitachi 1TB 5400RPM, Samsung 1.5TB 5400RPM
Corsair HW Series 750w (modular)
Cooler Master HAF 932 Advanced Blue Edition
CM Hyper 212+ CPU cooler, 3x 230mm + 1x 140mm case fans
Logitech MK320 (wireless)
30 Mb/s : 2 Mb/s
When I plug in speakers, there is no 2 channel option. It shows 2 channel for headphones, but not for the speakers.
Windows 7 Ultimate
Windows 7 Ultimate
Is it grayed out?
Could you give us more specifications on your computer, especially the exact make and model of your sound card>
Windows 7 Pro & Vista Home PremiumAthlon 64 3800+ (Orleans) 2.40GHz2GB DDR2 RAM DIMMNVIDIA GeForce 8500 GT 512 MB memory HDMI out
Cheap $399.00 E-Machine
Winfast
2GB DDR2 RAM DIMM
creative X-Fi Exteme 7..1 channel
Acer V223W 22" widescreen DVI
WDC WD5 500GB
WDC WD25 250GB
OCZ 550 watt
Gateway
2 fans
Sony Vaio
18MB/s down - .72MB /s up
It's a laptop, HP DV7-2185dx (same as dv7-2180us.). Nothing is greyed. It doesn't show an option. On the headphone properties, it shows "2 channel CD quality... etc etc" No idea what the card is- just says High Definition Audio Device.
Machine has a C2Q Q9000, 6GB RAM, Win 7 Ultimate.
Windows 7 Ultimate
Windows 7 Ultimate
Winfast
2GB DDR2 RAM DIMM
WDC WD5 500GB
WDC WD25 250GB
OCZ 550 watt
Gateway
2 fans
Sony Vaio
Not sure how I can reverse channels. By the way, I'm using external speakers, not the internal ones, not that it matters.
Downloading the new drivers.
Windows 7 Ultimate
Windows 7 Ultimate
Take out the right jack and put it in the left jack, the put the left jack in the right jack.
Anyway, the new drivers should work
Winfast
2GB DDR2 RAM DIMM
WDC WD5 500GB
WDC WD25 250GB
OCZ 550 watt
Gateway
2 fans
Sony Vaio
New drivers. Same problem.
I tried putting the jack in all three outlets. No difference. There is no "left jack/right jack." It's a single unit.
This really bugs me! LOL
Windows 7 Ultimate
Windows 7 Ultimate
If you happen to have a Realtech controller (check in Device Manager), type REAL into start/search and pull up the Audio Manager. There you can make speaker settings.
No Realtech. Just mono sound. And what frustrates me is I know it is a change I made somewhere that I can't find. I have a TV show I watch online, and the sound in it is only one channel, and that drove me nuts. I just wish I could remember what I changed!
Windows 7 Ultimate
Windows 7 Ultimate
I don't know how it happened but I lost my stereo in windows 7. I tried a whole bunch of things mentioned in this thread to no avail. Then I rolled back the driver for my sound device (Conexant HD audio device) and suddenly I'm in stereo again.
Windows7pro 64bit
Windows7pro 64bit
