Windows 7: Sound Problem after installing DAC Question?.
24 Jun 2016   #1
bluesjunior
Windows 7 Home Premium 64bit SP1
I bought a small DAC in order to use my vintage technics analogue stereo system for audio playback from my Win7 PC. I fitted it together via the toslink connection on the PC to the DAC input and then out via RCA connector cable to the AUX output on my amplifier. It works perfectly and I now get really good hi-fi quality sound output. The problem I am asking about is not about the DAC connection which works fine but, when I click on any folder on my hard drive eg to change music or just generally opening a folder I get this pop sound through the speakers. It is similar to the sound you get when connecting a jack plug to a live amplifier. Perhaps this has always been there but my 5.1 digital sound system wasn't affected so much as the full range studio monitors I am now using are. I realise this must be something to do with the Windows OS sounds but don't know if it is possible to turn them off or indeed if it is even advisable to turn them off. Has anyone experienced this and is there a solution?.
24 Jun 2016   #2
fireberd
I use my PC for my home recording studio so I have all system sounds set to "none". I can't have some Windows function interfere with recording.
Go to the Control Panel/Hardware and Sound and finally the Sound Panel. Click on the Tab for Sound.
See mine, below:
24 Jun 2016   #3
bluesjunior
See mine, below:
Thank you for a solution Fireberd. By the way I am also from Inverness but the original Scottish version very different weather from the Florida one I suppose. LOL.
25 Jun 2016   #4
fireberd
I get the "Inverness" thing every once in a while. Inverness Florida is a small town, on the Florida west coast (about 65 miles north of Tampa).
Sound problem perrsists even after new sound card
As some of you might remember, a few weeks ago I had a problem with sound after I built a new PC and kept my old Win 7 installation using sysprep: http://www.sevenforums.com/sound-audio/280175-onboard-sound-issue-new-pc-build-2.html#post2308990. The problem was that the volume levels were off, and...
No sound after installing sound drivers?
I installed a driver for my sound card, only to find out that sound just wouldn't play on my laptop. (It says that the sound is playing, it's just that it isn't coming through the speakers.) I know that the drivers are updated, so if you're going to ask if my driver is updated, the answer to that...
Sound Question
When I change a file and then close it I get no sound when the pop up ask if i want to make changes. I tried different things in control panel under "sounds" but was unable to fix this?
Little Question about sound...
No Audio Output Device is istalled. What does it mean??? No Driver or No Audio Card??? Please answer
Sound problem - need to 'scan for hardware changes' to get sound
Hi everybody I have a fairly strange problem with my Laptop. It came originally with Vista and a while ago I updated to Windows 7 32bit Home Premium. Since then I don't have any sound after booting the Laptop. By chance I found out that when I go into the device manager, right click on the sound...
Hardware & Devices
installing win 7 question
I have a question. first time poster on here. when installing win 7, can I just install it onto the hard drive in my CPU but i also notice people using Virtual PC but id rather not use any of that stuff. Is it possible to just install it directly onto my computer. Thanks, Dave
Installation & Setup
