Windows 7: No sound via SB Audigy LS through amp. Headphones work fine.
29 Jun 2016   #1
samstev
I've connected up an amp using auxiliary to my PC using RCA to the OUT (green) port in the back of my soundcard (SB Audigy LS).
I also have a pair of Corsair Vengeance wireless headphones connected via USB.
And lastly I have a Logitech webcam with built in microphone connected via USB.
I'm running Win7 Ultimate x64.
I get sound through the headphones fine and the built-in mic also works fine. I don't use the mic on the webcam but in the Sound\Playback Devices dialogue box, under the Recording tab I cab see it responding when I talk.
But, no matter what I do I cannot get any sound from the soundcard out to my amp. I've disabled the onboard Realtek drivers. I've changed the default speakers to the Audigy wherever I can find a setting. I looked in the BIOS (found nothing). I unplugged both the headphones and webcam, rebooted, still nothing.
I've previously had this machine plugged into an amp without a problem. I did rebuild the whole machine relatively recently and reinstalled everything. It has not been plugged into an amp for quite some time (the old amp died) but it's always just worked before. The amp I'm running is only days new and my CD player and turntable both play fine. I can hear feedback through my speakers as I plug the cable into the soundcard, but once it's in, nothing.
Please does anyone have any suggestions as to what I can try?
29 Jun 2016   #2
fireberd
First, when you use a USB device, the sound card doesn't really come into play.
Do you have a regular headset (not USB) that you can try on the GREEN speaker jack on the SoundBlaster? That would confirm whether there is a problem related to the sound card or if the problem is in the cable or amp.
Check the Device Manager, Sounds section. Is the SoundBlaster listed and does it show working OK or an error?
You could also try the Realtek. I have a recording studio so I'm attuned to audio quality and I find the Realtek is just as good on sound playback as the SoundBlaster's. Although I have high end equipment for recording, I use Realtek for all PC audio.
01 Jul 2016   #3
samstev
I mucked about with drivers, did as you suggested with an older pair of headphones, still no joy. Getting annoyed and desperate by this stage, I opened the machine and re-seated the card. That did the trick! Thanks heaps for your help, appreciated.
Sound in my headphones half work after just getting them.
Just got a pair of Fatal1ty Gamin Headsets and after waking up the next day half the headphones on each side work only hear sound in the back. I looked in my Audio Settings and everything looked normal and Drivers were updated like my computer told me it was. Help i dont know what to do.
Sound card problem - headphones work, notebook speakers don't
Hi all, I just bought an old Toshiba A210 laptop and I'm dealing with a couple of (minor) problems. As the title says, I've tried every conceivable control, I can't get any sound from the speakers. No hissing sound, nothing, completely silent. Headphones work fine though. I checked device...
Sound just completely disappears but Headphones work?
Hello, I am completely at a loss! Having tried everything from updating drivers, uninstalling soundcard rebooting and installing again and finally system restore. The problem is if the pc is left on for a while the sound will go. Speakers work fine. Here is my system sound spec: ...
Sound won't work form Speakers but works in headphones
Hi everyone, I have Sony Vaio CW26. Yesterday Sound stopped working from Speaker, it's still working from headphones. I tried to restore the system but the farther point I found was done 3 hours ago...... anyway, I found out too that the USB port ( which is next to the audio output) is not...
HP620 No sound from speakers only headphones work
HP620 laptop running windows 7 32bit Home Premium Plugged in headphones for an hour. When I removed them the laptop speakers no longer function. Checked volume and mute. Checked playback device area and laptop speakers are enabled and indicated as functioning. Only headphones work. Deleted...
Speakers work fine but Headphones don't
I'm running Win 7 Pro. After installing the Realtek High Definition Audio update, my speakers work fine, but my headphones don't . Say's headphones are not plugged in. Apparently this was a problem in Vista as well. Anyone know a solution? Thanks.
