Windows 7: Possible fix when headphone jack has no audio, everything else normal
13 Jul 2016   #1
link626
windows 7
Possible Solution:
Put Windows to Sleep, then wake it up. Headphone jack audio will be restored.
Problem:
Headphone jack randomly stopped outputting audio.
volume control at 100% and appearing to work normally. Laptop internal speakers worked fine.
Windows detects headphones plugged in, but no sound in headphones.
Uninstall sound card and realtek drivers, reboot did not fix problem.
Tested Linux live CD and headphones worked in Linux.
So hardware was definitely not broken. Only Windows was broken.
(I had this issue recently, so I'm leaving this here for search engine results and anyone who has this problem in the future)
15 Jul 2016   #2
greatfulAnon
Windows 7 64 bit
Holy crap i love you! I reinstalled Windows 7 recently to fix this problem after trying just about everything, but after a couple of Windows updates my headphone jack wasn't working again. Found your post after filtering search results to recent hits and this trick worked! This problem only creeped up a short while ago, so maybe it has to do with recent Windows updates.
Inputting Microphone and Headphone audio into the line in jack
Hello all, firstly; apologies for any headaches caused, however, until I buy a capture card I'm recording gameplay through a camera (the quality to my surprise isn't bad either). However picking up the audio requires me to turn up the TV volume quite a lot and also the mic (on my headset) to 100 +...
How to configure headphone jack and speak jack together
I'd like to plug my speakers into the back speaker jack and headphones to the front jack. I can't do this and have both work at the same time. I have a cheapo Insight speaker with a volume puck that lets me plug a headphone jack but then the speakers turn off. Seems to me with front panel...
Headphone jack light?
I have a red light in my headphone jack when I'm using windows 8 but then when I get back onto Windows 7 (dual boot) the light doesn't turn on. Does anyone know how I could turn it on? Toshiba A500
Hardware & Devices
Front audio headphone jack reversed stereo...
I have a Gigabyte GA-P55-UD5 motherboard with on-board sound by Realtek, and my case is Thermaltake's "Element G". I connected the front panel audio cable to the designated connection on the motherboard, however, whenever I plug-in my headphones, the stereo is reversed! Meaning that the...
headphone jack unplugged
my front panel head phone jack s not detected ... it shows dat its unplugged in control panel sound devices.... earlier it was working perfectly. n recently i reinstalled windows 7 after re installing ,the headphone jack is not detected.. please help me......
Headphone jack only in mono
The headphone jack on my new laptop is only playing in mono. Anybody know why? Edit: Actually it's in stereo, but it doesn't pan all the way. If I pan an audio track 100% to the right or left, it only pans about halfway in my headphones (or in my speakers if that's what I plug in).
