Windows 7: HDMI cable for audio or keep my 4.1 w/soundcard? need help w/HDMI
27 Jul 2016   #11
ThrashZone
Win-7-Pro64bit 7-H-Prem-64bit
Quote   Quote: Originally Posted by Tactics View Post
lol I've read many threads about that name/type receiver I probably should check it out but I def. don't need any more wires back there! lol
Yamaha has hdmi connections too
I'd be interested in Fireberd's take on the receiver deal he is our expert
27 Jul 2016   #12
Tactics
64 bit
"Good" 5.1 systems have two prerequisites. (1) how much you are willing to spend (2) individual preference - what sounds really great to you may not be that good to someone else. You have to listen to ones in your price range to see which one you want. If you can't audition them, buy them at a site that has liberal return policy in case you buy something you find out you don't like.
I have a recording studio and I can tell you no one agrees 100% with any mix I do.
ok thx good info.
27 Jul 2016   #13
Tactics
64 bit
Quote   Quote: Originally Posted by ThrashZone View Post
27 Jul 2016   #14
ThrashZone
27 Jul 2016   #15
fireberd
I don't have any surround sound systems so I really can't comment on the hardware such as the Yamaha.
27 Jul 2016   #16
ThrashZone
Yea the receiver gives more speaker options for the most part and use it as a central unit
But still be able to connect all devices to it with hdmi cable box/ bluray dvd player/ t.v./....
It has newer style speaker connections and older 2 wire connections so if one had good old speakers they would be able to use them and not have to buy a new surround sound speakers system
The newer model I post is 4k compatible too
Should I use an HDMI or HDMI-DVI cable to connect to my monitor?
I have a video card with both a DVI and an HDMI output and a monitor with only an HDMI input. Should I connect my monitor to my PC with an HDMI cable or with a DVI - HDMI cable?
Graphic Cards
HDMI Audio issues with cable and gfx card...
Hey guys, first time poster here. I have a palit 9600gso smart 1gb ddr2 card. i recently bought a viewsonic vx-2253mh LED monitor. now i've hooked up my gfx card with my monitor using a hdmi cable but i don't get any sound. i also have a GB GA G41-M-Combo mobo. i was wondering if anyone could...
hdmi cable to LG tv no audio
hi, i have my pc connected to a LG flatron 22" tv by hdmi cable the picture is fine but the audio does not play through the tv, a jack cable from the pc to the tv does not work either, if i use the jack plug into separate speakers it will play the audio through the speakers. i have checked in...
Need Help : Audio won't work when I attach my HDMI cable to my laptop
So yeah, I use a HDMI - HDMI cable to my laptop whenever I want to watch DVDs on it. It used to be that the audio would work, but now that does not seem to be the case. I've tried rolling back to previous versions but to no avail. And yes, i've lurked through all the previous threads but to...
How to automatically change audio device when inserting HDMI cable?
Hello, My lapotop is HP Pavilion 9750 running Windows 7 Enterprise (with the latest updates). When I'm inserting the HDMI cable to view my screen on the TV it automatically shows the video, but I have to manually change the default playback from "Speakers" (Realtek High Definition Audio) to...
HDMI Cable/Good video/No audio
I see on the forum that this has been a problem for a long time but I don't see where anyone has figured it out yet. If I missed something please enlighten me. I built up a computer to use with my HDTV. A Gigabyte GA-E350N-USB3 MB loaded with W7x64. Audio and sound worked fine when it was...
