Windows 7: HDMI cable for audio or keep my 4.1 w/soundcard? need help w/HDMI
26 Jul 2016   #1
Tactics
64 bit
Hello quick question so i'm clear and to see what you would suggest.
I have a new upgrade LG 55 inch 4k TV connected to my PC via HDMI to GTX970 I've read this TV supports audio also via the same HDMI cable plugged in to my video card. I'm a huge gamer.
Right now I have a X-Fi Xtreme Gamer sound card connected to a 4.1 Logitech setup w/sub. I've been using this for years and it works great for surround sound when available and EAX is always a plus SO whats my benefit to 86 the 4.1 and just go HDMI?
In that case I lose the 4 speaker setup correct and just use audio from the TV?? I can't see the advantage for this unless i'm missing something big. I don't use SPDIF output or the Dolby digital or DTS encoder from the card I assume all that you need a receiver.
Can I use HDMI output for audio and STILL use my 4.1 speakers? I don't want to invest in a receiver or anything like that at this point. What would you do if you were me? i'm at work now but I read if I go into the sound properties/playback devices I can choose HDMI output? I'm curious to see how that works.
thx!
26 Jul 2016   #2
fireberd
Windows only allows one default audio playback device. e.g. HDMI or Speakers (your sound card). HDMI audio is generated on a sound chip in the Video card. You don't have all the options you do with a Sound card.
26 Jul 2016   #3
Tactics
64 bit
ok thx i'm probably gonna keep the sound card and speaker but I know nothing about HDMI audio so want to make sure i'm not missing some huge new technology for audio.
26 Jul 2016   #4
Layback Bear
Windows 7 Pro. 64/SP-1
A quality sound card and speakers will perform better than HDMI audio in my opinion.
26 Jul 2016   #5
ThrashZone
Win-7-Pro64bit 7-H-Prem-64bit
I would guess the exception would be if you were using a bitching Yamaha receiver
26 Jul 2016   #6
Tactics
64 bit
lol I've read many threads about that name/type receiver I probably should check it out but I def. don't need any more wires back there! lol
26 Jul 2016   #7
Tactics
64 bit
Quote   Quote: Originally Posted by Layback Bear View Post
thx for that feedback!
26 Jul 2016   #8
AddRAM
Windows 7 Pro x64 Windows 10 Pro x64
You can do it however you want, you`ll just have to keep switching the audio device, but your tv will never sound as good as your audio system, fortunately I have a Sony 7.1 system I switch to if I ever want to watch a movie from my PC on my 40" Sony Bravia.
27 Jul 2016   #9
Tactics
64 bit
Quote   Quote: Originally Posted by AddRAM View Post
ok cool thats what I was thinking no way the TV will sound as good. Nice 7.1 thats sweet I should at least go to 5.1 to have that center channel b/c when in PC mode the TV doesn't have sound only when i'm back in cable mode. I'm such a neat freak the 4.1 and wires are perfect and to rip them all down and do a 5.1 i'll be like arrgggggg
Can you suggest any good 5.1 setups? I'll search Google also
27 Jul 2016   #10
fireberd
"Good" 5.1 systems have two prerequisites. (1) how much you are willing to spend (2) individual preference - what sounds really great to you may not be that good to someone else. You have to listen to ones in your price range to see which one you want. If you can't audition them, buy them at a site that has liberal return policy in case you buy something you find out you don't like.
I have a recording studio and I can tell you no one agrees 100% with any mix I do.
Should I use an HDMI or HDMI-DVI cable to connect to my monitor?
I have a video card with both a DVI and an HDMI output and a monitor with only an HDMI input. Should I connect my monitor to my PC with an HDMI cable or with a DVI - HDMI cable?
Graphic Cards
HDMI Audio issues with cable and gfx card...
Hey guys, first time poster here. I have a palit 9600gso smart 1gb ddr2 card. i recently bought a viewsonic vx-2253mh LED monitor. now i've hooked up my gfx card with my monitor using a hdmi cable but i don't get any sound. i also have a GB GA G41-M-Combo mobo. i was wondering if anyone could...
hdmi cable to LG tv no audio
hi, i have my pc connected to a LG flatron 22" tv by hdmi cable the picture is fine but the audio does not play through the tv, a jack cable from the pc to the tv does not work either, if i use the jack plug into separate speakers it will play the audio through the speakers. i have checked in...
Need Help : Audio won't work when I attach my HDMI cable to my laptop
So yeah, I use a HDMI - HDMI cable to my laptop whenever I want to watch DVDs on it. It used to be that the audio would work, but now that does not seem to be the case. I've tried rolling back to previous versions but to no avail. And yes, i've lurked through all the previous threads but to...
How to automatically change audio device when inserting HDMI cable?
Hello, My lapotop is HP Pavilion 9750 running Windows 7 Enterprise (with the latest updates). When I'm inserting the HDMI cable to view my screen on the TV it automatically shows the video, but I have to manually change the default playback from "Speakers" (Realtek High Definition Audio) to...
HDMI Cable/Good video/No audio
I see on the forum that this has been a problem for a long time but I don't see where anyone has figured it out yet. If I missed something please enlighten me. I built up a computer to use with my HDTV. A Gigabyte GA-E350N-USB3 MB loaded with W7x64. Audio and sound worked fine when it was...
