Windows 7: Regular sound muting issue
29 Jul 2016   #1
100ec
My sound mutes every... about 1.5 seconds. I have to spam the up and down arrow keys to hear my Skype call.
EDIT: Here's my problem.
When I start up my computer, I get about 1-2 minutes of uncut sound until it mutes. Also, the computer doesn't say it's muted. It just pretends that everything is normal. The only way to fix this is to adjust my sound by at least 1% sound or mute/unmute it. The problem gets increasingly more and more annoying by the minute because the time between mutes shortens. After a while, the first paragraph happens.
30 Jul 2016   #2
AmericanPharaoh
Windows 7 Home Premium 64-bit
Please, start a new thread for your issue, thanks!
John
31 Jul 2016   #3
100ec
Quote   Quote: Originally Posted by AmericanPharaoh View Post
John
Thank you, I've changed my post.
31 Jul 2016   #4
MoxieMomma
OEM Windows 7 Ult (x64) SP1
Hi, @100ec:
Is this the same computer as the one for which you are being helped at another forum:
https://forums.malwarebytes.org/topi...uting-problem/
If so, it can be confusing, inefficient, and counter-productive to work simultaneously on the same problem in multiple venues. The helpers cannot know what steps are being taken or changes are being made to the system by other helpers.
It's a "too many cooks" situation.
If you prefer to be helped here at sevenforums.com, rather than in your other topic at the other forum, I respectfully suggest that you please notify your helper at the other forum. That way, he can close your thread there and focus his time/effort on others who need help.
<just a friendly suggestion>
MM
04 Aug 2016   #5
100ec
Quote   Quote: Originally Posted by MoxieMomma View Post
Hi, @100ec:
MM
Oh... thanks. I just wanted to get this problem over with and not have to deal with it anymore... it's really annoying and I thought: "I should get more help because the OP had the exact same problem." My post was moved to a new thread, so it didn't go as planned.
Gigaware usb speakers muting sound after unplugging
Anyone else have a problem with Gigaware usb speakers muting the computer after they are unplugged? This requires a restart to get the sound back. Dell Inspiron N4110, SSD. Thanks!
Network Issue- Ping Spikes at regular intervals
This is a series of pings that I just did, and almost without fail, every 8th ping will spike from 500ms-1000ms. This is happening at such a regular interval that it can't be coincidence, but I couldn't find anything similar to this issue. Is this some sort of ISP choking? Pinging to my router has...
Network & Sharing
Sound muting/un-muting rapidly, have to press keys twice, etc.
About an hour ago Windows 7 went on the fritz. The sound rapidly mutes and un-mutes, I intermittently have to press the windows key (as well as some other keys) more than once, my start menu pins disappeared, and sometimes I'm clicking on buttons or menus and have to click twice. I don't believe...
Muting HDMI Sound
Is there any keyboard key or combination which will mute HDMI sound? I have a Radeon 5670 video card which connects to an HD TV through HDMI. Sound works fine except I cannot adjust the sound level or mute the system sound without navigating through several layers of graphic, mouse activated...
PC How can i lower my sound even more than 1 without muting it (W7)
My headphones are too good and i dont have any other ones so they can be REALLY loud even on 1 out of 100 sound. So is there a way or a program that can lower the volume more than windows 7 allows.
Why does muting sound in Live TV mute all Windows sound?
Using a tuner card in my computer. When I mute the sound in Media Center Live TV, it mutes all the Windows sound. Any way to get around this? Would like to be able to mute the Live TV & run closed captioning while keeping all the other Windows sounds. Can't seem to find any options to set. ...
Media Center
