Windows 7: Need help about HDMI sound to tv
12 Aug 2016   #1
AceDuk
Windows 7 Ultimate 32bit
Hi. i have HDMI cable and i don't have sound when i connect pc to tv
Using Asus Nvidia G210 can anyone help me to fix it?
12 Aug 2016   #2
fireberd
Do you mean there is no sound on the TV? or that there is no sound on PC speakers after connecting the HDMI cable?
On most systems, if an HDMI cable is connected Windows will automatically switch the default audio playback device from the "Speakers" (PC sound) to HDMI. If you want PC sound with HDMI connected you must manually switch it back.
If your problem is no PC sound on the TV, first make sure HDMI was set as the default audio playback device. Second, HDMI sound is usually generated in the video card (I couldn't find out if that is the way this card works but if it is make sure the HDMI audio (video drivers) are installed and that that there is no error in the Device Manager). On some older video cards, you must supply S/PDIF audio from the PC to the Video card.
12 Aug 2016   #3
AceDuk
no sound on tv
12 Aug 2016   #4
AceDuk
no error in device manager, here is the screenshot
12 Aug 2016   #5
fireberd
There is no HDMI showing. Either its disabled in the Device Manager, proper driver not installed, or it needs S/PDIF from the PC motherboard.
Post a screenshot of the Device Manager, Sounds section.
12 Aug 2016   #6
AceDuk
12 Aug 2016   #7
fireberd
There is no HDMI sound driver installed. However, I can't find anything in the ASUS manual or on their site that this video card has HDMI Audio.
Suggest you go to the NVIDIA site and download the latest driver for this model. If it has HDMI audio, the driver will install it.
Drivers - Download NVIDIA Drivers
12 Aug 2016   #8
AceDuk
i have already installed latest driver.
did i need this to install?
12 Aug 2016   #9
AceDuk
now i installed everything that is on screenshot and no effects
12 Aug 2016   #10
fireberd
I suspect there is no audio on that video card. OR you must supply an S/PDIF audio connection to the card from the PC to have
HDMI audio. But, sadly I think its there isn't any HDMI audio, as I could find no reference to it.
Sound not working, Only have HDMI Sound Output, But no HDMI port in PC
Hi there, My sound is not working. I only have a HDMI Sound output. However, I don't have any HDMI Output in my computer. I reinstalled windows a couple of times lately, but i don't know for sure if thats the problem. Right now im using Windows 7 32-Bit, My hardware specs are: CPU: Intel Duo 2...
Drivers
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
NO SOUND TROUGH HDMI ON ACER AX3400-U3032 and No HDMI Icon in sound se
Had to replace motherboard from authorized acer parts dealer now I get no sound through HDMI port. I did through the original board until it got fried by electrical surge. Can any one help or send me a picture of the inside the same model to make sure all jumpers on the motherboard are in the...
No sound through speakers.Jack not being detected.HDMI sound only?
So I've got a problem,I changed my case 2 days ago and everything went great,all working as it should be.Up until an hour ago,when the lid got stuck in one of the little clips so after a quick bang it went in.But then I lost my picture on both monitors. So I went to investigate,I ended up...
no sound through tv via hdmi, sound plays through laptop speakers (idt
Yesterday I installed a new external hard drive - following the installation - my sound no longer played through my television (video is fine, HDMI connection) and sound now comes ONLY through the laptop speakers. The option for HDMI Audio doesn't appear in the 'sound' menus. I have 'checked'...
No sound via audio jacks, but sound via hdmi.
I recently done a new build, not with the same specs I have on here; i5 2500k p8z77-m pro sapphire radeon 6870 I cannot get any sound through the front+back headphone jacks, realtek doesnt detect any audio devices, however i can mess around with the settings to get windows to say i have...
