Windows 7: Front Panel audio jack not working
13 Aug 2016   #1
negima2k10
windows 7 ultimate x64
Hi
I have related problem, but with diff. specs. can someone help me?
13 Aug 2016   #2
fireberd
Tell us about your problem. Is it the headphone jack or the microphone jack or both? Has it ever worked?
If its the headphone jack, what type of headphone are your trying to use?
Front Audio Jack, right sided speakers/cup not working
Hello, I'm Artekis. A year ago, sevenforums helped solved my BSOD problem! Now I'm back for help on audio problems. I recently noticed that the front audio ports of my Windows 7 PC do not work properly. I plugged in both speakers and my headset, and the right side of the speakers do not work as...
Front jack not working for Realtek HD Audio on Windows 7
Hi all, I've just installed Windows 7 and was very happy to see all the hardware working, even my Realtek HD Audio sound card, except the front jacks. On windows XP I could solve this by with the Sound Manager that comes with the realtek drivers, and select the "Disable front panel jack...
How do i output sound through the back panel jack and the front jack
Hey guys! I want to output sound both through the headphone jack on the front of my case and the sound jack at the back of the computer, how would i do this? I looked around in the sound setttings and the realtek audo and couldn't find anything.
front panel audio jack doesnt work after sleep mode until restart
I have realtek ALC898, part of gigabyte Z77 UD5h mobo, windows 7 ultimate 64bit. Rear jack speakers always work, sound always works. But after sleep, the front panel audio jack does not work, ie headphones silent. Workaround 1) go to device manager, disable realtek high definition audio, then...
Hardware & Devices
Front I/O Audio Jack not working.
Hello, Last month I built my own computer. I am having a problem with my Front I/O audio jacks. - Headset is Beats by Dr. Dre Solo HD - I have went into BIOS and enabled my Front I/O - My front I/O is properly connected to my Motherboard - My driver is Realtek HD R267 (Newest driver)
Cpu front panel head phone jack is not working
My cpu front panel headfone&speaker jack is not working.If iam inserting headset &mic its not detected.if i am connecting it from back then it is working.Is it a hardware problem or software problem.................? I have checked out my cpu internal connections by removing the cabinet .Every...
General Discussion
