Windows 7: No audio sound
14 Aug 2016   #1
ellenc
Windows 7 Professional
No audio sound
I've just spent the last 1.5 hours grappling with this problem that happens frequently. I have Logitech speakers which are properly connected (green light on), I have checked: Device Manager, both Intel(R) Audio Properties and Realtek HD Audio "device working properly, gone into services.msc/all necessary services Started/Automatic, checked the Volume icon does not have a red check, etc.. (I am unable to do chkdsk or sfc /scannow: the command prompt boxes flash for a second and then disappear!) This is such a vexing problem. As always, your help is greatly appreciated. ellenc
14 Aug 2016   #2
torchwood
Hi Ellen,
is there a Audio manger in control panel.
try running dskchk/sfc from an elevated command mode.
Roy
14 Aug 2016   #3
ellenc
No audio playback
I honestly believe I couldn't survive my computing life without this forum. Thank you ever so much for your help. I was joyous when I heard sound blasting from the speakers. ellenc
 No audio sound
No sound in back audio panel jack - Realtek HD Audio Manager
Hello, I have Windows 7 Ultimate 64 bit and I have a problem with sound. When I plug my speakers in front panel I have output audio, but in back panel I don't. :confused: My Audio Manager looks like this, but front panel is enabled and back panel is disabled. It does not recognize back...
Suitable/Compatible Free Audio Driver for Dolby Advanced audio sound
I have a Lenovo Thinkpad E550 laptop with Windows 7. There are no enhancement features in the speakers properties section. I have realtek card reader...do I need realtek driver? I read that not all motherboards use realtek audio chips. What would be a suitable/compatible FRE audio driver to...
Drivers
No sound from onboard audio (Realtek High Defition Audio)
Hey Guys, So here it goes, I normally have my Logitech z-5500 speakers connected to the onboard sound output (green,yellow and black) as well as my Plantronics 780 connected to the front panel USB port. I used to be able to play music through any one without any problems, just had to select...
VIA High Definition Audio ,no sound digital audio (S/PDIF)
Motherboard :asus p5kpl-am se (no sound card) vendor id :1106 device id :0397 problem: digital audio (S/PDIF) no sound OS : Windows 7 ultimate 32bit i've download numerous latest driver on the official website of VIA and installed it, yet no different.. i wonder if anybody can help me with...
start navigation sound (continuation from Sound & Audio)
continuation from this thread: http://www.sevenforums.com/sound-audio/107468-start-navigation-sound-playing-no-reason.html here's the Highjack log file:
System Security
IDT High Def Audio, buzzing sound when playing any sort of audio.
Hello, Starting about a week ago whenever any audio is being played through my computer (speaker or headphone) I will hear a buzzing sound and occasionally the audio with skip. This happens weather I am playing audio that is being streamed from the internet or that is on my computer directly....
