Windows 7: Problem connecting wireless headphone to desktop PC
16 Aug 2016   #1
animegazone
Had searching the internet for two weeks, but still failing.
The closest solution I found is this: How to connect wireless headphones to PC
The problem is exactly the same as mine, but using the solution given, my wireless headphone still won't pair to my desktop PC.
Here is my devices:
- Wireless headphone: Jabra Move Wireless
- Windows 7 Ultimate, x64
- Bluetooth 2.0 USB Dongle
I don't think the other specification such motherboard, graphic card, etc is needed, so I will not write them here, unless they are needed to find the solution.
What I'm trying to achive:
I want to play music from my desktop PC using my wireless headphone through the USB bluetooth dongle.
Problems:
- Even after my wireless headset is already listed in control panel, it seems that its still not completely paired.
The bluetooth headphone/headset in "Sound" properties is still blank and nothing happened if the "Connect" option (by its popup menu) is clicked.
- In the Wireless headphone menu, I still can't click "Listen to music". Nothing is happened.
Here is my wireless headphone properties:
What should I do to make my wireless headphone completely paired with my desktop PC and fully working?
Any kind of help is appreciated.
Thanks.
18 Aug 2016   #2
Eric3742
Windows 7 x64
Are you on Wireless or Bluetooth.
Usually for Bluetooth, it should called Bluetooth, NOT Wireless.
Wireless is the same as internet on either 2.4 GHz &or 5 GHz.
Which one are you referring to; Wireless OR Bluetooth
19 Aug 2016   #3
animegazone
Quote   Quote: Originally Posted by Eric3742 View Post
Sorry, my bad.
I mean bluetooth.
27 Aug 2016   #4
animegazone
I finally able to connect my bluetooth headshet to my Windows 7 using bluesoleil.
Thanks for everyone who already put any efforts into my thread.
Search this Thread:
Advanced Search
Problems with connecting to wireless on Vaio desktop.
I have a Vaio desktop with windows seven ultimate x32. I am having problems connecting my desktop to my WiFi. It is a Net gear wireless router based off Charter communications. My computer gives me no options to connect to my wireless network unlike my laptop. I go through the control panel -...
Network & Sharing
Problem with connecting to wireless but no internet
I have read through a few of these threads, and haven't been able to solve my problem. I'm running Win 7 Home Premium 64 bit, I have a D-Link DIR-600N router, and up until about a week ago everything seemed fine. So now the situation is that I can connect to the wireless network, but cannot load...
Network & Sharing
Problem connecting to internet at wireless public access point
Hello! I regularly burn the midnight oil at my favorite local coffee shop. I recently purchased a new laptop which seems to have problems connecting to the wireless public router the coffee shop has for its guests. When it works, you are immediately taken to a landing page in your browser where...
Network & Sharing
Problem connecting to WiFi - wireless icon not working
Hello, I seem to have a problem with my WiFi. Left-clicking the wireless icon in system tray doesn't work as in literally nothing happens. When I open the network and sharing center and click on "connect to a network" then also nothing happens. Right now it's only a minor problem, because my...
Network & Sharing
problem connecting to wireless in win 7
Hi I purchased Toshiba Satellite C650D laptop 2-3 weeks back. I installed windows 7 and can connect to the internet by wire. My brother's laptop is registered with the ISP so I have to mask my MAC address. I am posting snapshots of the problem. I get error 691. I tried resetting the router....
Network & Sharing
Issues connecting desktop to wireless router
Hi there, I am in a bit of a pickle with my current residence. My leaser will not allow me to have an extra cable modem install near the only place I can have my desktop. So my next course of action was to get a wireless adapter and connect it to a wireless router. Here is the entire map ...
Network & Sharing
