Problems with no onboard sound Intel D865glc
jeepn30
7:49 PM
I just installed Windows 7 on my desktop computer that has been in storage for the last 2 years. The only issue I'm having is no sound. I have an Intel D865glc motherboard, 2.8 p4 processor, 1.5 gigs of ram. I checked bios to make sure onboard sound was enabled. When it installed I have some soundmax program, but no sound. I checked the speakers with my laptop and they work fine. I looked at intel's website, and see evidently there is no windows 7 driver support for the board. I tried downloading the realtek '97 codec. I got static sound for any audio that was played (finally got sound but probably not the right driver). Does anybody have any recommendations before I break down and buy a compatible windows 7 sound card?
Windows 7 Home PremiumPentium 4 2.8Ghz1.5 gig DDR 400Ge Force 5500 FX
Home built
Pentium 4 2.8Ghz
Intel D865GLC
1.5 gig DDR 400
Ge Force 5500 FX
built in sound
Seagate 1 Tb SATA
Maxtor 160 Gig IDE
ATX
The onboard intel sound problem has been investigated several times on this forum with the latest of suggestions being as you've stated buying a compatible addon sound card. Their may be other replies but that's my suggestion. Good luck and welcome to sevenforums. Fabe
Windows 7 ultimate 64 bit / XP Home sp3intel Core 2 Duo E8400 3.0ghz8 gigs 1066 OCZ Fata1tyEVGA GTX 580 Call of Duty Black Ops Edition
Asus P5ND bios 1401
Asus 24in LCD's 2MS X2
1920x1080p @60Hz
OCZ 700W GameXtreme
NZXT Apollo
Download 19.83 Upload 0.97
