Windows 7: No System Audio After MOBO Upgrade
25 Oct 2016   #1
Busterbrown
Windows 7 Home Premium 32-bit
i just upgraded my MOBO to an AsRock MB-970A-G / 3.1
Now I get no system audio whatsoever!
Via my control panel, Realtek Digital Output is checked off.
Previously, I had audio rigged coming from two Gearhead Flat panel speakers, USB powered, and they
worked just fine. They are plugged into an external USB port on the new MOBO.
So, guess I've got some system reconfiguring to do?
25 Oct 2016   #2
oscer1
win 7 64 bit
Hi what's listed for the default play back device. what if you plug speakers into the green port do you get sound?
25 Oct 2016   #3
Busterbrown
Quote   Quote: Originally Posted by oscer1 View Post
Realtek Digital Output - default PBD.
Speakers have only USB connections.
And there is NO system audio, BTW.
Thanks.
25 Oct 2016   #4
oscer1
win 7 64 bit
could you post a screen shot of the default playback screen and do you have any yellow marks in device manager? do you have a pair of headphones that you could plug into the green port to test for sound. could you also provide a link to the speakers you have?
25 Oct 2016   #5
Busterbrown
a) Link to Gear Head speakers: Gear Head | Speakers
(These speakers performed fine before MOBO upgrade Monday)
b) No yellow marks in Device Manager
c) Ear buds connected to green port played back audio OK (YouTube audio track)
d) Screen shot of default playback screen (I gather) - Attached
26 Oct 2016   #6
Busterbrown
Think I'm covered with rue here...The USB speakers are POWERED by USB, but in the tangle of connectors behind the workstation, there's no doubt a 3.5 mm audio connector--connected to the speakers--that got pulled from the green audio port during installation of the new MOBO...
Think this is a great big DUH! on Yours Truly!
26 Oct 2016   #7
oscer1
win 7 64 bit
It happens that's why I wanted to see link to speakers usually their a place to plug into audio output. Glad got it working
Search this Thread:
Advanced Search
BSOD after mobo / memory upgrade - system freezes - etc
So, let me see. I upgraded my system to an MSI 990FXA-GD80 with GSkill Ripjaws X 16gb 1600 (in 2x8gb sticks that came packaged together so presuming they matched them.) F3-1600CD9-16GXM that GSkill says is compatible with the MSI board. Though the bios only sees it as 1333 when set to auto. No luck...
BSOD Help and Support
HDMI Audio AND Realtek MoBo Audio Simultaneously
Hi, Not sure if this is possible, but thought I'd toss it out there... I'd like to have audio sent via HDMI to my monitor while at the same time using the MoBo output jack for a subwoofer. I've only been successful with one or the other by itself in any configuration I've been able configure....
Realtek audio, Gigabyte mobo: strange-sounding audio, mic not working
I have a self-assembled desktop PC - full specs in the signature below, but in short, it has an AMD Phenom II X6 1090T processor on a Gigabyte GA-970A-DS3P mainboard, which uses a Realtek Azalia ALC887 on-board sound system. I have no loudspeakers and listen to the computer sound exclusively...
No audio - Faulty mobo ?
I am having some issues with my computer regarding sound. I don't have any of it! My computer was recently RMA'd due to a faulty PSU and video card. I just received it back and the speakers that I used before no longer work. I figured it was a driver issue and simply downloaded the RealTek...
mobo audio input help
hi all just a quickie, not realy a problem just not quite sure lol. i have just bought a new surround sound setup with 3 leads to conect 2 pc. am i reading this right? the 3 inputs on my mobo are 1xmic 1xheadphone 1xaux.but wen using a surround system they all change 2 inputs for the speakers?...
Mobo upgrade Q6600
I have a Gateway FX7024 w/a very overclockable Q6600. Can someone recommend a good mobo that hasnt been discontinued? I am running DDR2 5300 memory that compatibility is a must.. thxs
Hardware & Devices
