Windows 7: Headset microphone not recording when headset is default audio device
3 Weeks Ago   #1
iBSODed
Windows 10 Ultimate x64
Hello
So three days ago I wiped all of my drives and installed Windows 10. I have a Corsair Vengenace 2100 headset. I installed the realtek drivers from ASUS download section for my motherboard and then I installed the headset drivers.
The problem is that my headset does not record anything through the microphone if I set it to be the default device for audio output. If I have my other computer speakers as the default output device my microphone works just fine.
This goes for all the USBs in the back of the motherboard. The headset works just great if I plug in the wireless reciever in the front of the computer.
I have tried to reinstall the drivers multiple times and checked a bunch of different settings in the sound manager in windows but nothing seems to work.
Have also googled all kinds of things but nothing seems to relate to my problem.
I do not have any external sound card plugged into my computer.
Thanks for any help provided!
EDIT: Can be closed as I found the win 10 forum after I made the thread. Sorry!
Search this Thread:
Advanced Search
My new headset not recording System Audio Help.
I use Audacity and I would use WASAPI and did not need Stereo Mix enabled with my old headset. Now with my new headset I have to use Stereo Mix, WASAPI won't work anymore, pretty weird issue to say the least. I installed Asus Realtek Driver 6.0.1.7354 I record in Mono. My mic boost is at +0.0db. I...
Headset microphone not working
I recently got the SADES SA-708 and to my surprise the microphone was not working. I have tested it on another laptop so I know it's not a problem with my headset. I'm not even sure if my computer is recognizing the headset. Any help would be appreciated.
My headset microphone not working
Hello, Recently I bought a Turtle Beach Earforce X12 headset. And the sound works fine but when I tried out the Microphone nothing happened, like it wasn't there. I have updated my drivers several times tried but no success. When I go to Recording section in Sound, it shows the microphone as a...
Will a Headset microphone still work if I cut it off the Headset?
I have a almost broken headset, but the microphone still works fine, The microphone is connected on the wire right before the headset, Its not actually touching the headset itself. Would this microphone still work if the headset was cut off? Sorry but I can't manage to take a photo but
Hardware & Devices
Headset's microphone is not appearing on the recording devices list.
I recently bought a Philips SHM7110U/10 headset to hopefully get better audio than my laptop's current microphone while recording with Fraps. Fraps is currently using my laptop's default microphone, which can be changed by setting another microphone to the default. I read several articles on how...
Unable to set bluetooth headset as (default) playback device
I have a bluetooth headset, and I've paired/added it to my laptop. I check all its services and the drivers installed fine. But for some reason, the sound still goes through the speakers. I went to Control Panel->Hardware and Sounds->Sounds and it only showed 2 entries- Digital Audio (HDMI) and...
Hardware & Devices
