No Audio Output Device is installed
  1. Posts : 2
    windows 7 32bit
    Hi guys, i just installed Windows 7 put all drivers, but audio don't want to install, said that smth about "no device found to install driver".
    Sound Icon is with a red circle with a "x". In Device manager no sound device as all. I have a Hp Dv 9925nr with audio conexant 221.
    Please Help (sorry for my english) !!!
  2. Posts : 5,747
    7600.20510 x86
    Hey.
    Right click on the audio device in the device manager. Properties. Details tab. Change dropdown to hardware ids. Copy and paste the results here.
    I'll try to find or edit a driver that will work for you.
  3. Posts : 2
    windows 7 32bit
    In device manager i don't have the sound icon, i don't where is it ?!!
  4. Posts : 5,747
    7600.20510 x86
    Go into the bios and see that the onboard audio is enabled.
    If so, please post a screenshot of the device manager with the sound section maximized.
  5. Posts : 1
    Windows /
    I have the same problem..
    Here is what I found under "hardware ids".
    HDAUDIO\FUNC_01&VEN_10EC&DEV_0880&SUBSYS_1462E603&REV_1008
    The soundcard is onboard on a "MSI RS482M4" and Windows finds a driver durring install, but yet I get the message "No Audio Output Device is installed" :-(
    I allready installed the ATI chopset drivers from MSI's homepage,
    but the sound drivers has no effect.
    Hope you can help me.
  6. Posts : 1
    Windows 7 Ultimate x32
    Same problem. It worked at first, here's my DXdiag output while it was working:
    System Information
    Time of this report: 6/10/2010, 06:20:37
    Machine name: OKTYN-PC
    Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255)
    Language: English (Regional Setting: English)
    System Manufacturer: PINNACLE MICRO
    System Model: PROLINE DQ45CB
    BIOS: BIOS Date: 02/08/08 17:50:03 Ver: 08.00.10
    Processor: Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz (4 CPUs), ~2.7GHz
    Memory: 1536MB RAM
    Available OS Memory: 1512MB RAM
    Page File: 782MB used, 2243MB available
    Windows Dir: C:\Windows
    DirectX Version: DirectX 11
    DX Setup Parameters: Not found
    User DPI Setting: Using System DPI
    System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
    DxDiag Version: 6.01.7600.16385 32bit Unicode
    DxDiag Notes
    Display Tab 1: No problems found.
    Sound Tab 1: No problems found.
    Input Tab: No problems found.
    Sound Devices
    Description: Speakers (High Definition Audio Device)
    Default Sound Playback: Yes
    Default Voice Playback: Yes
    Hardware ID: HDAUDIO\FUNC_01&VEN_11D4&DEV_1882&SUBSYS_80861003&REV_1003
    Manufacturer ID: 1
    Product ID: 65535
    Type: WDM
    Driver Name: HdAudio.sys
    Driver Version: 6.01.7600.16385 (English)
    Driver Attributes: Final Retail
    WHQL Logo'd: Yes
    Date and Size: 7/14/2009 01:51:47, 304128 bytes
    Other Files:
    Driver Provider: Microsoft
    HW Accel Level: Basic
    Cap Flags: 0xF1F
    Min/Max Sample Rate: 100, 200000
    Static/Strm HW Mix Bufs: 1, 0
    Static/Strm HW 3D Bufs: 0, 0
    HW Memory: 0
    Voice Management: No
    EAX(tm) 2.0 Listen/Src: No, No
    I3DL2(tm) Listen/Src: No, No
    Sensaura(tm) ZoomFX(tm): No
    Then all of a sudden this!!:
    System Information
    Time of this report: 6/22/2010, 23:45:39
    Memory: 3584MB RAM
    Available OS Memory: 3064MB RAM
    Page File: 750MB used, 5377MB available
    DxDiag Notes
    Sound Tab 1: No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer.
    Sound Devices
    Description:
    Default Sound Playback: No
    Default Voice Playback: No
    Hardware ID:
    Manufacturer ID:
    Product ID:
    Type:
    Driver Name:
    Driver Version:
    Driver Attributes:
    WHQL Logo'd:
    Date and Size:
    Other Files:
    Driver Provider:
    HW Accel Level: Emulation Only
    Cap Flags: 0x0
    Min/Max Sample Rate: 0, 0
    Static/Strm HW Mix Bufs: 0, 0
    HW Memory: 0
    I don't a sound card, i've downloaded several versions of Win7 sound drivers from Intel: Connexant does not install, says no hardware for driver, Realtek installs but no sound.
    PLEASE HELP!!!
