No Audio Output Device is installed
Forsaj1
12:18 AM
Hi guys, i just installed Windows 7 put all drivers, but audio don't want to install, said that smth about "no device found to install driver".
Sound Icon is with a red circle with a "x". In Device manager no sound device as all. I have a Hp Dv 9925nr with audio conexant 221.
Please Help (sorry for my english) !!!:confused:
windows 7 32bitAMD Turion 64 *2 (2000 Mhz)250 GbNvidia Geforce Go 7150M
HP Pavilion dv 9925 nr
windows 7 32bit
250 Gb
Conexant 221
Hey.
Right click on the audio device in the device manager. Properties. Details tab. Change dropdown to hardware ids. Copy and paste the results here.
I'll try to find or edit a driver that will work for you.
7600.20510 x86P4 550 3.4 GHz HT running at 3.5 GHzOCZ 2 GB(2x1GB) DDR400mHz running @ 414 mHzHIS Radeon HD 3850 IceQ 3 Turbo HDMI Dual DL-...
self built
7600.20510 x86
MSI PM8M3-V (MS-7211 v1.x) Micro-ATX mainboard
HIS Radeon HD 3850 IceQ 3 Turbo HDMI Dual DL-DVI AGP
MOTU Traveler firewire studio interface 192 kHz 24 bit
22" widescreen Acer X223W LCD, 17" Compaq P75 CRT
1680x1050 and 1280x1024
SATA I x2 WD, 400 GB and 120 GB, SATA 2 WD Caviar Black 1 TB
350W generic
Cybertronpc, it glows blue
stock cpu fan, Ice-Q 3 gpu and system, many case fans
Logitch Classical Keyboard 200
Logitech Mediaplay cordless
1792/448 kbits/sec
SATA II PCI fake RAID adapter, 1 GB Readyboost, original ATI Remote Wonder (even works with WMC perfectly), Logitech Rumblepad 2 game controller x2
In device manager i don't have the sound icon, i don't where is it ?!!
windows 7 32bit
250 Gb
Conexant 221
Go into the bios and see that the onboard audio is enabled.
If so, please post a screenshot of the device manager with the sound section maximized.
self built
7600.20510 x86
350W generic
1792/448 kbits/sec
I have the same problem..
Here is what I found under "hardware ids".
HDAUDIO\FUNC_01&VEN_10EC&DEV_0880&SUBSYS_1462E603&REV_1008
The soundcard is onboard on a "MSI RS482M4" and Windows finds a driver durring install, but yet I get the message "No Audio Output Device is installed" :-(
I allready installed the ATI chopset drivers from MSI's homepage,
but the sound drivers has no effect.
Hope you can help me.
Windows /AMD Athlon(tm) 64 Processor 3500+ 2.19 GHz1,00 GBon board
MSI RS482M4
Windows /
MSI RS482M4
1,00 GB
on board
onboard
Same problem. It worked at first, here's my DXdiag output while it was working:
System Information
Time of this report: 6/10/2010, 06:20:37
Machine name: OKTYN-PC
Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255)
Language: English (Regional Setting: English)
System Manufacturer: PINNACLE MICRO
System Model: PROLINE DQ45CB
BIOS: BIOS Date: 02/08/08 17:50:03 Ver: 08.00.10
Processor: Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz (4 CPUs), ~2.7GHz
Memory: 1536MB RAM
Available OS Memory: 1512MB RAM
Page File: 782MB used, 2243MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7600.16385 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
Sound Devices
Description: Speakers (High Definition Audio Device)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_11D4&DEV_1882&SUBSYS_80861003&REV_1003
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: HdAudio.sys
Driver Version: 6.01.7600.16385 (English)
Driver Attributes: Final Retail
WHQL Logo'd: Yes
Date and Size: 7/14/2009 01:51:47, 304128 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Then all of a sudden this!!:
System Information
Time of this report: 6/22/2010, 23:45:39
Memory: 3584MB RAM
Available OS Memory: 3064MB RAM
Page File: 750MB used, 5377MB available
DxDiag Notes
Sound Tab 1: No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer.
Sound Devices
Description:
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID:
Product ID:
Type:
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
HW Accel Level: Emulation Only
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
HW Memory: 0
I don't a sound card, i've downloaded several versions of Win7 sound drivers from Intel: Connexant does not install, says no hardware for driver, Realtek installs but no sound.
PLEASE HELP!!!
Windows 7 Ultimate x32Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz (...3584MB RAMNVIDIA GeForce 8500 GT
PINNACLE MICRO
PROLINE DQ45CB
3584MB RAM
On-board High Definition Audio Device
SyncMaster Magic CX2333SW(Digital)
WDC WD1600AAJS-00B4A0 SATA Device
350W
General
CPU fan + 2 Box fans
