Upgraded to W7. No sound. Creative Xfi card. Help!
rocketdescends
7:49 PM
Boston
I upgraded from Windows XP to Windows 7 Home Premium 32 bit. My sound card is a Creative X-Fi Audio Processor (WMD). I am not sure if that is the actual model name. That is the name that the device manager gives me. RE-installing drivers from Creative doesn't help. Tried the Daniel_K drivers and nothing seems to help. It just seems that Windows 7 is not even recognizing that there is a card installed at all! I have a Dell XPS 600 Pentium D 3.20 ghz 2 gig ram. I have spent several hours trying to figure this out. Please help!
Windows 7 Home Premium 32 bitIntel Pentium D2 gig DRMRadeon 1900XTX
Dell XP 600
Intel Pentium D
2 gig DRM
Radeon 1900XTX
Creative XFi Audio Processor (WDM)
Hi.
In device manager, right click on the card. Properties. Details tab. Change dropdown to hardware ids. Copy and paste the results here and I'll see what I can do.
Please no screenshot as alternative. That only makes it more difficult for me. Thanks.
7600.20510 x86P4 550 3.4 GHz HT running at 3.5 GHzOCZ 2 GB(2x1GB) DDR400mHz running @ 414 mHzHIS Radeon HD 3850 IceQ 3 Turbo HDMI Dual DL-...
self built
7600.20510 x86
MSI PM8M3-V (MS-7211 v1.x) Micro-ATX mainboard
HIS Radeon HD 3850 IceQ 3 Turbo HDMI Dual DL-DVI AGP
MOTU Traveler firewire studio interface 192 kHz 24 bit
22" widescreen Acer X223W LCD, 17" Compaq P75 CRT
1680x1050 and 1280x1024
SATA I x2 WD, 400 GB and 120 GB, SATA 2 WD Caviar Black 1 TB
350W generic
Cybertronpc, it glows blue
stock cpu fan, Ice-Q 3 gpu and system, many case fans
Logitch Classical Keyboard 200
Logitech Mediaplay cordless
1792/448 kbits/sec
SATA II PCI fake RAID adapter, 1 GB Readyboost, original ATI Remote Wonder (even works with WMC perfectly), Logitech Rumblepad 2 game controller x2
hi.
In device manager, right click on the card. Properties. Details tab. Change dropdown to hardware ids. Copy and paste the results here and i'll see what i can do.
pci\ven_1102&dev_0005&subsys_10031102&rev_00
pci\ven_1102&dev_0005&cc_040100
Dell XP 600
Intel Pentium D
2 gig DRM
Radeon 1900XTX
Alright. I made you a little something somethin because it's so old, it needed it.
Download this link and extract it to a folder.
Then, right click on the audio device in the device manager.
Update driver software. Browse my computer. Let me pick. Have disk. Browse.
Now navigate to wdma_emu.inf in the extracted folder
and double click on it. Click ok. Click next and let it install.
You can then right click the speaker icon in the system tray near the clock and go to playback devices to set it as you want. You can right click on any shown and then set it to show disconnected and disabled devices, too.
self built
7600.20510 x86
350W generic
1792/448 kbits/sec
The "update driver" button is greyed out. It will not let me access that.
Dell XP 600
Intel Pentium D
2 gig DRM
Radeon 1900XTX
Heh heh, immediately after right clicking on it, left click update driver software.
self built
7600.20510 x86
350W generic
1792/448 kbits/sec
Installed. Restarting computer now. I will let you know.
Dell XP 600
Intel Pentium D
2 gig DRM
Radeon 1900XTX
The sound icon at on the system tray still has the red x by it. See attached picture. Says no devices are installed. I made sure to check off disabled devices too.
Dell XP 600
Intel Pentium D
2 gig DRM
Radeon 1900XTX
How does it look in the device manager? It should have installed well as I made the .inf specific for your device. Can you post a screenshot of it and also the general tab too?
self built
7600.20510 x86
350W generic
1792/448 kbits/sec
It says that the device cannot start.
Dell XP 600
Intel Pentium D
2 gig DRM
Radeon 1900XTX
Alright. I guess the best things you can do at this point is to make sure the chipset drivers are the latest, even if you have to try out Vista ones from VIA (or whatever chipset the motherboard uses.)
And also, update the system bios to latest, then disable all unused ports like serial, parallel, floppy etc...
Then install the audio card driver again.
self built
7600.20510 x86
350W generic
1792/448 kbits/sec
Windows Update says all my drivers are up to date, but Driver Updater Pro says my drivers are out of date. Should I shell out the $30 for this software? :P
Dell XP 600
Intel Pentium D
2 gig DRM
Radeon 1900XTX
No way. Those programs can and do mess up Windows installs very quickly.
Your best bet is to find another manufacturer and motherboard that uses the same exact chipset. Then install the chipset drivers from them, for yours. If you find something like that and need help, let me know. Look for Vista ones.
self built
7600.20510 x86
350W generic
1792/448 kbits/sec
Going to the Dell website they don't even have Vista drivers for this old computer. I am at a loss on what to do. Should I buy a new card? Maybe this one is just too damn old. Could you suggest one? I play a lot of music and games. I know that I really need to invest in a new motherboard and a dual or quad core chip.
Dell XP 600
Intel Pentium D
2 gig DRM
Radeon 1900XTX
Buying a new card is probably not going to help.
Doesn't the motherboard have onboard audio that you can enable in the bios?
Wait a second though....nForce4? That should work.
Try installing chipset drivers from here.
self built
7600.20510 x86
350W generic
1792/448 kbits/sec
I installed those Nvidia drivers from that link. Btw that $30 program detected one less problem after those Nvidia drivers were installed. I am getting close to desperate and might buy it. The worse case scenario is I am out $30 and if it messes up my computer I can use do a system restore.
So anyways after installing those drivers I restarted then I reinstalled the audio driver you made for me and restarted. Nothing. Right now I deleted the entire driver. Dusted off my original Soundblaster Xfi Cd and starting from scratch.
Dell XP 600
Intel Pentium D
2 gig DRM
Radeon 1900XTX
Ok so after reinstalling the whole driver from my original soundblaster disc and then installing the audio driver you gave me nothing has changed. I am really desperate at this point. *sigh*
Dell XP 600
Intel Pentium D
2 gig DRM
Radeon 1900XTX
Windows 7 Home Premium x64 - Mac OS X 10.6.4 x64Intel Core 2 Duo T9300 2.5 GHz4GB Kingston DDR2-800NVIDIA Geforce 8600M GT (512MB Model)
JFT02
WUXGA Standard Laptop Display
1680*1050
Standard Laptop Power Supply
Standard Laptop Case
Standard Laptop Cooling
Synaptics Touchpad
Dell XP 600
Intel Pentium D
2 gig DRM
Radeon 1900XTX
Awesome Zidane! +rep
self built
7600.20510 x86
350W generic
1792/448 kbits/sec
