Onboard Sound Issue
bigmck
Very Senior Member
3:38 PM
Houston, Texas
I have had Win 7 installed for almost a week. I like other posters on here have had a problem with Win 7 and onboard audio. I have read alot of websites, downloaded alot of drivers and put alot of time into the issue. This morning I solved the problem and thought I would pass it on to you. I would guess that this solution will apply to only a very small percentage of you, but the way that I solved the problem was to plug the wire into the speaker..............:rolleyes:
Windows 7 Home Premium 32-Bit - Build 7600 SP1Intel Core i3-2120 3.30GhzKingston 4 GB DDR3 1333 mhzAMD Radeon HD6670
AMD Radeon HD6670
Asus VE228
1440 X 900
Corsair CX600M == 600 Watt
Three 120 mm Fans
Microsoft Natural 4000
Microsoft Custom Optical 3000
If you have a Zotac Geforce 9400 GT 512MB,. why would you want to use onboard sound?
Windows 7 Pro & Vista Home PremiumAthlon 64 3800+ (Orleans) 2.40GHz2GB DDR2 RAM DIMMNVIDIA GeForce 8500 GT 512 MB memory HDMI out
Cheap $399.00 E-Machine
Winfast
2GB DDR2 RAM DIMM
creative X-Fi Exteme 7..1 channel
Acer V223W 22" widescreen DVI
WDC WD5 500GB
WDC WD25 250GB
OCZ 550 watt
Gateway
2 fans
Sony Vaio
18MB/s down - .72MB /s up
I'm not, but I do have onboard sound and a card. As I said there have been issues with onboard sound and Win 7. Never mind. The post was just an attempt at humor. You see there was no issue...........
AMD Radeon HD6670
Asus VE228
1440 X 900
Three 120 mm Fans
