No "windows sounds" under sound mixer
  1. Posts : 2
    Hi, my windows 7 sound has been too loud, anything above 25 is starting to get rather loud. Ive looked around on google etc and found that the "Windows Sounds" slider is meant to be the equivilent to the old XP "wave" slider. However, my sound mixer doesnt have it. I asked a friend and they said that they had it on their mixer, but the only difference between us really is that hes using ultimate 32 bit and im using professional 64bit.
    If anyone knows how to adjust/show the windows sound slider, id be greatly appreciative if you would share that knowledge
  2. Posts : 1,614
    Windows 7 Pro & Vista Home Premium
    We would need to know the exact make and model of your sound card
    Also...................
  3. Posts : 2
    im not using a sound card atm, im using the G35 headset from logitech. i mean, i HAVE a sound card, but its not in use, i didnt even bother installing the drivers.
    also, done
