System Tray- Volume grayed out
Burger23
1:29 AM
The VOLUME in Sytem icons is grayed out. Sound has been working fine- but somehow it got turn OFF in the system try. I tried this link, and selected RESTORE DEFAULTS when in the System Icon Area- nothing happens.
Any ideas? Thanks...
Sounds like something got pooched a bit for 7 there. Try running the system file checker with the dvd you burned in the drive to see if that will repair the Windows file for that. Is this for onboard sound or an addon?
If you have an addon like a Creative sound card you would rely on the volume control panel and audio console options seen there and wouldn't even use the Windows adjuster. Your other option is to go into the Control Panel>Recovery and run the system restore back before this was first seen. Something you added on lately may have knocked it out on you.
    W7 Ultimate x64/W10 Pro x64/W11 Pro Triple Bo...AMD Phenom II X4 975 Deneb 3.6ghz - 965 2nd r...Kingston Hyper X DDR3 1600 1.5v 16gb - Hyper ...MSI HD Radeon 5750 1gb - MSI HD Radeon 6450 o...
    Custom builds = 2
    Asus 1440x900 - HP 1600x900
    Zalman CNPS9900A
    W7 Pro x64/W11 ProAMD Deneb 3.6ghz - 965Kingston Hyper X Fury 8gbMSI HD Radeon 6450 DVI Output
    CUSTOM ASSEMBLY
    W7 Pro x64/W11 Pro
    1600x1080
    NZXT Vulcan mini tower
    DSL 5G
Thanks for your quick reply, Night Hawk. I tried what I should have tried first, a REBOOT- that fixed the issue.:D
That will do it too! I run into not seeing the volume control in the system tray on a few occasions where going to Start>Programs>Creative and then the volume panel item there still won't see the icon appear until rebooting.
Hey what can you say? It's still beta! ;)
    Custom builds = 2
    Zalman CNPS9900A
    CUSTOM ASSEMBLY
    W7 Pro x64/W11 Pro
    1600x1080
    DSL 5G
